I was writing some sample to use a XamComboEditor inside a grid in a template column as well as a Temple Column Layout. Is it assumed that Binding the selected item does not work the same way a standard combo works?? when i replace the XamComboEditor with a standard ComboBox the samples work as expected. I have seen on the samples site that a value converter is used to wire up the binding. Is this required. I am using ria services with EF.
Hello spicish2222,
I am just checking if you got this worked out, or you still require any assistance, or clarification on the matter.
Would you please explain in more details your issue so we can try and find a solution for you.
apparently binding does not work correctly in the XamMultiColumnComboEditor either.
very disapointing
I am sorry to hear that, if you get back to researching this issue please open a new thread referencing this one’s link.
no we have not resolved the issue. i have not had time to write a sample project. due to the time lines of the current project we had to abondon that control for the time being which is quite disappointing.
