Whenever I select a row via selecting the first cell in a column group, the scrollbar resets to zero, scrolling the cell off the screen. It does not seem to happen to regular columns or 2nd-Nth column of a column group. It also doesn't seem to matter whether the cell is read-only or what type of control it contains?
How can I prevent this from happening?
Here are my settings:
<ig:XamGrid.EditingSettings> <ig:EditingSettings AllowEditing="Row" IsEnterKeyEditingEnabled="True" IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="True"/> </ig:XamGrid.EditingSettings>
<ig:XamGrid.SelectionSettings> <ig:SelectionSettings RowSelection="Multiple" CellClickAction="SelectRow" /> </ig:XamGrid.SelectionSettings> <ig:XamGrid.DeferredScrollingSettings> <ig:DeferredScrollingSettings AllowDeferredScrolling="Default"> </ig:DeferredScrollingSettings> </ig:XamGrid.DeferredScrollingSettings>
I tried reproducing your issue but I am not seeing what you are reporting, could you provide a small sample with concise steps to reproduce so that this can be investigated?
I've also tried explicitly scrolling the cell into view via different events such as GotFocus, ActiveCellChanged, CellEnteredEditMode, etc. but nothing seems to work.
This also happens when the row is in edit mode already, and I tab through the cells, as soon as I tab to the first cell in a group, the scrollbar resets.
