1095
XamDataTree in container with height="auto" bug ... ?
I reported a problem back in 10.3 of this component (see ref links below). Now im a bit puzzled if the problem i now have is a related to the same or not, but ill leave this challenge to you guys.
Problem description :
I have a XamDataTree inside a "container" with a height set to auto. When i open and close a node with more then 370 children the whole app crashes with a "Layout cycle detected" message.
See attached mock up application to reproduce the error.
Steps to reproduce crash :
1. Start application.
2. Close then Open the treeview component.
For some weird reason i get an absolute limit of 370 elements it can handle. If i add 371 it crashes.
Any thoughts around this ? But still most important : Can you suggest any workaround for the bug?
We currently have a live product with this problem and thus this is critical for us.
Ref:
Old thread : http://community.infragistics.com/forums/t/51728.aspx
Old bug DevID in the internal tracking system : 64775
Old bug Support case : CAS-60332-5BRPBN
XamDataTreeCrash.zip
  • 34510
    I have logged this issue with our engineering staff as a development issue 97133 so they can examine this further. I have also created case CAS-79352-G8B97Q for you so that you can track the issue.  I will post the resolution here after development issue 97133 is resolved.
    Let me know if I may be of further assistance.
