I have an application that uses the XamGrid and i would like to navigate throught it by buttons.
When the XamGrid is in a "normal" state as that :
The navigation i implemented works fine (even with filters).
The problem concern the group, when i want to pass to the next element as that :
I got an exception because the next element taken is the value inside the cell (here a string).
Is there a way to solve it ?
I join a .sln to show you how i implemented the navigation.
Regards.
Hi Fabian,
Thanks for posting your solution. I’m sure it will be interesting to others.
Please let me know if you have further questions.
I tried you suggestion bu it didn't work, i already had a binding on the ActiveItem and affect it or the element produce the same issue.
But i found a solution by using the following properties :
- ScrollCellIntoView : it shows the good element,
- IsSelected : on the row to highlight it,
- IsActive : on the first cell of the row to get the data of the row.
I attach the solution if anyone else is interest.
Regards ans thanks for the help.
Fabien.
HI,
I didn't see your response. Please take the time you need to review.
I was wondering if you had further questions.
Sorry I didn't try what you suggested yet. I'll write you in few days.
