245
How to Hie tooltip ?
Hi , i just want to hide the tooltip of a symbole element , how to make this ? Thanks
  • 2505
    Hi bouhmid86,
    To achieve this, you could try to implement an approach similar to the following:
    XAML:
        <Grid x:Name="LayoutRoot" Background="White">
            <Grid.RowDefinitions>
                <RowDefinition Height="*"/>
                <RowDefinition Height="auto"/>
            </Grid.RowDefinitions>
            <igMap:XamMap x:Name="map1" Grid.Row="0">
                <igMap:XamMap.Layers>
                    <igMap:MapLayer x:Name="statesLayer" Imported="statesLayer_Imported">
                        <igMap:MapLayer.Reader>
                            <igMap:ShapeFileReader Uri="Shapefiles/usa/usa_st" DataMapping="Name=STATE_NAME; Value=POP1997; Caption=STATE_ABBR"/>
                        </igMap:MapLayer.Reader>
                    </igMap:MapLayer>
                </igMap:XamMap.Layers>
            </igMap:XamMap>
            <Button x:Name="btnRemoveTexasToolTip" Content="Remove TX Tooltip" Click="btnRemoveTexasToolTip_Click" Width="300" Height="100" Grid.Row="1"/>
        </Grid>
    CB:
            private void statesLayer_Imported(object sender, Infragistics.Controls.Maps.MapLayerImportEventArgs e)
                if (e.Action == Infragistics.Controls.Maps.MapLayerImportAction.End)
                    Point originNebraska = map1.MapProjection.ProjectToMap(new Point(-101.60, 42.90));
                    Point originTexas = map1.MapProjection.ProjectToMap(new Point(-96.3, 29.9));
                    SymbolElement elementNebraska = new SymbolElement() { SymbolOrigin = originNebraska, Caption = "Nebraska", SymbolType = MapSymbolType.Diamond, SymbolSize = 20, ToolTip = "NebraskaSymbolTooltip" };
                    SymbolElement elementTexas = new SymbolElement() { SymbolOrigin = originTexas, Caption = "Texas", SymbolType = MapSymbolType.Hourglass, SymbolSize = 20, ToolTip = "TexasSymbolTooltip" };
                    map1.Layers[0].Elements.Add(elementNebraska);
                    map1.Layers[0].Elements.Add(elementTexas);
            private void btnRemoveTexasToolTip_Click(object sender, RoutedEventArgs e)
                foreach (MapElement el in map1.Layers[0].Elements)
                    if (el.Caption == "Texas")
                        el.ToolTip = null;
    Best Regards,
    Milana Zhileva
