I upgraded my project to v11.2 and I'm trying to export the content of my xamGrid with the new xamGridExcelExporter.
Here is my code:
private void bt_excel_Click(object sender, RoutedEventArgs e) { Workbook dataWorkbook = new Workbook(); Worksheet sheetOne = dataWorkbook.Worksheets.Add("Data Sheet");
dataWorkbook.SetCurrentFormat(WorkbookFormat.Excel2007);
excelExporter.Export(this.datagrid, dataWorkbook); SaveExport(dataWorkbook); }
private void SaveExport(Workbook dataWorkbook) { SaveFileDialog dialog;
dialog = new SaveFileDialog { Filter = "Excel files|*.xlsx", DefaultExt = "xlsx" };
bool? showDialog = dialog.ShowDialog(); if (showDialog == true) { using (Stream exportStream = dialog.OpenFile()) { dataWorkbook.Save(exportStream); exportStream.Close(); }
Here is the error detail:
PersistenceGroup elements don't match elements in stream.
at Infragistics.Persistence.PersistenceManager.LoadGroup(PersistenceGroup group, Stream stream, PersistenceSettings settings) at Infragistics.Persistence.PersistenceManager.Load(DependencyObject obj, Stream stream, PersistenceSettings settings) at Infragistics.Persistence.PersistenceManager.Load(DependencyObject obj, Stream stream) at Infragistics.Controls.Grids.XamGridExcelExporter.CopySourceGridToExporterGrid() at Infragistics.Controls.Grids.XamGridExcelExporter.ExportInternal() at Infragistics.Controls.Grids.XamGridExcelExporter.Export(XamGrid grid, Workbook workBook, Worksheet workSheet, PackageFactory pf, Boolean useAsync) at Infragistics.Controls.Grids.XamGridExcelExporter.Export(XamGrid grid, Workbook workBook) at GEC.GecExtendedDataGrid.bt_excel_Click(Object sender, RoutedEventArgs e) at System.Windows.Controls.Primitives.ButtonBase.OnClick() at System.Windows.Controls.Button.OnClick() at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e) at System.Windows.Controls.Control.OnMouseLeftButtonUp(Control ctrl, EventArgs e) at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, Int32 actualArgsTypeIndex, String eventName)
This issue was resolved in the service release for 11.2 and 12.1.
Please let me know if you are still having issues after upgrading to the latest service release.
Sincerely,
Valerie
Developer Support Supervisor - XAML
www.infragistics.com/support
what this ever resolved?
i have the same issue with a grid that is tied to a domaindatasource. it used to work but just stopped
I have logged this as development issue 97611.
Sincerely,ValerieDeveloper Support Engineer Infragisticswww.infragistics.com/support
unfortunately i will not close this thread yet.
I modified the sample, and moved the style resources under the xamgridex resources.(it is the same for xamGrid also)
Now when i try to export, i get the following error "System.InvalidOperationException: There was an error generating the XML document. ---> System.InvalidOperationException: The type System.Windows.Style was not expected. Use the XmlInclude attribute to specify types that are not known statically.", as you can see in the attached sample.
Also, when we call the Export method to the XamGridExcelExporter, we pass as parameter the grid on which we will perform the export. Why don't you use reflection to create an instance of the requested grid, if the event is not handled by the developer? I tried it on the attached sample and it seems to work....
Michael
I spoke with development on this and in order to resolve this you need to indicate the type to the persistence framework in order to rehydrate the inherited grid. This can be accomplished by handling the XamGridRequested event on the XamGridExcelExporter and passing in a new instance of the grid being exported:
XamGridExcelExporter excelExporter = new XamGridExcelExporter(); excelExporter.XamGridRequested += new EventHandler<XamGridExcelExporterRequestedEventArgs>(excelExporter_XamGridRequested); ….
void excelExporter_XamGridRequested(object sender, XamGridExcelExporterRequestedEventArgs e){ e.XamGrid = new XamGridEx();}
Please note there are known issues and limitations using the XamGridExporter, including conditional formatting, which can be found at:
http://help.infragistics.com/NetAdvantage/Silverlight/2011.2/CLR4.0/?page=xamGrid_Known_Issues_Limitations_ExcelExporter.html
