I just tried to update my solution from 11.1 to 11.2 by using versionUtility.
After analysing the solution, it stops with a failure, but does't displays any errorMessage (check pdf).
Log file content:
03:39:50: Running User Interface Version 11.2.20112.100003:39:50: Gathering volume and assembly information.03:40:09: Index was out of range. Must be non-negative and less than the size of the collection.Parameter name: index03:40:09: at System.ThrowHelper.ThrowArgumentOutOfRangeException() at System.Collections.Generic.List`1.get_Item(Int32 index) at Infragistics.VersionUtilitySupport.Core.File.Types.WebSite.GetAllSiteFiles(Boolean analyze) at Infragistics.VersionUtilitySupport.Core.File.Types.WebSite.Analyze() at Infragistics.VersionUtilitySupport.Core.File.Types.SolutionFile.Analyze()
Hope someone can give me a solution asap.
Cheers,
Enrico
Hello Enrico,
This is just a follow up on the thread if you have any questions in regards to the help documentation provided for upgrading a silverlight project or upgrading the project manually. In the provided links contains steps for NetAdvantage 2011 Vol 2.
Let me know if you have any questions with this matter. Thank you.
Thanks for the file attachment on the thread.
For guidelines on upgrading a silverlight project can be found in the help documentation: http://help.infragistics.com/NetAdvantage/Silverlight/2011.2/CLR4.0/?page=Upgrading_Your_Silverlight_Projects_10.2.html.
Also another option is that the project can be upgraded manually: http://help.infragistics.com/NetAdvantage/Silverlight/2011.2/CLR4.0/?page=Upgrading_Your_Projects_from_NA_SL_10.1_to_10.2_Manually.html.
Hi Duane,
I attached some log files for you.
Hope it helps.
Hello Enrico Gebauer,
It will be helpful to provide the log file as an attachment to the thread. The path location for the logs created can be found here: "C:\Users\admin\Documents\Infragistics\Tools\Version Utility".
