I am using Infragistic version 10.3.20103.2105. I want to add SelectAll header box in column and on select/unselect that I want to check/uncheck all the check boxes in all the rows in that column.
Can you please help me how to do this.
Thanks!
hi,
Good article...
Hi guriq,
Please feel free to contact me if you need further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
I am attaching a sample illustrating a 10.3 WebDataGrid with a templated field where the header checkbox checks/unchecks all cell checkboxes.
Here is the javascript code used in this scenario:
function HeaderCheckboxChanged() { //variable to hold the status of the checkBox. The tricky part is to access the input element. var checkBoxState = $find("WebDataGrid1").get_columns().get_column(1).get_headerElement().children[0].children[0].checked; //iterate through the rows and set the checkBox states and cell values for (i = 0; i < $find("WebDataGrid1").get_rows().get_length(); i++) { $find("WebDataGrid1").get_rows().get_row(i).get_cell(1).get_element().children[0].checked = checkBoxState; } }
And the corresponding grid markup:
<ig:WebDataGrid ID="WebDataGrid1" runat="server" AutoGenerateColumns="False" DataSourceID="SqlDataSource1" Height="350px" Width="400px"> <Columns> <ig:BoundDataField DataFieldName="Name" Key="BoundColumn_0"> <Header Text="BoundColumn_0" /> </ig:BoundDataField> <ig:TemplateDataField Key="TemplateField_0"> <ItemTemplate> <asp:CheckBox ID="CheckBox1" runat="server" /> </ItemTemplate> <HeaderTemplate> <asp:CheckBox ID="CheckBox2" runat="server" onchange="HeaderCheckboxChanged();" /> </HeaderTemplate> <Header Text="TemplateField_0" /> </ig:TemplateDataField> </Columns> </ig:WebDataGrid>
Best Regards,Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://es.infragistics.com/support
Hi Petar,
I am using Infragistic version 10.3.20103.2105. I am not able to access WebDataGrid reference with 'ig_controls' in Java Script function. Also I am not able to use '<Templates>' tag in HTML code.
Can you please share one sample with me which has been done with version 10.3.20103.2105. It will be easy for me to understand.
Please let me know if you need further assistance.
