I have a situation where I need to create/configure a conditional format column in code, but my code version will not render my conditional icons like the XAML version does. Here's what my grid with conditional format looks like in XAML:
<ig:XamGrid Name="theGrid" AutoGenerateColumns="False"> <ig:XamGrid.ConditionalFormattingSettings> <ig:ConditionalFormattingSettings AllowConditionalFormatting="True"/> </ig:XamGrid.ConditionalFormattingSettings> <ig:XamGrid.Columns> <ig:TemplateColumn HeaderText="Status" Key="SomeStatus"> <ig:TemplateColumn.ConditionalFormatCollection> <ig:IconConditionalFormatRule RuleExecution="None" IsTerminalRule="True"> <ig:IconConditionalFormatRule.Rules> <ig:ConditionalFormatIcon ValueType="Number" Value="2" Operator="GreaterThanOrEqualTo"> <ig:ConditionalFormatIcon.Icon> <DataTemplate> <Image Source="/AppNamespace;component/Images/image2.png" /> </DataTemplate> </ig:ConditionalFormatIcon.Icon> </ig:ConditionalFormatIcon> <ig:ConditionalFormatIcon ValueType="Number" Value="1" Operator="GreaterThanOrEqualTo"> <ig:ConditionalFormatIcon.Icon> <DataTemplate> <Image Source="/AppNamespace;component/Images/image1.png" /> </DataTemplate> </ig:ConditionalFormatIcon.Icon> </ig:ConditionalFormatIcon> </ig:IconConditionalFormatRule.Rules> </ig:IconConditionalFormatRule> </ig:TemplateColumn.ConditionalFormatCollection> </ig:TemplateColumn> </ig:XamGrid.Columns></ig:XamGrid>
Here's the attempt of creating this in code:
var templateColumn = new TemplateColumn();templateColumn.Key = "SomeStatus";templateColumn.HeaderText = "Status";templateColumn.ConditionalFormatCollection = new ConditionalFormatCollection(); var iconFormatRule = new IconConditionalFormatRule() { RuleExecution = Infragistics.EvaluationStage.AfterFilteringAndPaging, IsTerminalRule = true};
// Create icon 2's condition.var image2 = new ConditionalFormatIcon { ValueType = IconRuleValueType.Number, Value = 2, Operator = IconGroupOperator.GreaterThanOrEqualTo };image2.Icon = (DataTemplate)XamlReader.Load("<DataTemplate xmlns=\"http://schemas.microsoft.com/client/2007\"><Image Source=\"/AppNameSpace;component/Images/image2.png\" /></DataTemplate>");iconFormatRule.Rules.Add(image2);
// Create icon 1's condition.var image1 = new ConditionalFormatIcon { ValueType = IconRuleValueType.Number, Value = 1, Operator = IconGroupOperator.GreaterThanOrEqualTo };image1.Icon = (DataTemplate)XamlReader.Load("<DataTemplate xmlns=\"http://schemas.microsoft.com/client/2007\"><Image Source=\"/AppNameSpace;component/Images/image1.png\" /></DataTemplate>");iconFormatRule.Rules.Add(image1);
theGrid.Columns.Add(templateColumn);
Does anyone know why this would not work when constructing the equivalent template column w/conditional format in code?
John
I am very glad that you have managed to solve your issue. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thanks for the feedback.
It turns out that there were two issues that I had to deal with before I got it to work.
First, I needed to add the IconConditionalFormatRule to the ConditionalFormatCollection (I'd created it but never added it to the parent collection). Second, I had to change the way that I was setting the Template column's Key since we have a unique way that we have to data bind.
I have been looking into the issue that you have described and I could not manage to reproduce it. I have created a sample application in which I am adding a TemplateColumn with conditional formatting applied in code. I have tested the sample application with both build 11.1.20111.1004 and the latest service release and the condition formatting is applied.
Please let me know if you can reproduce the behavior that you have described with my sample application or I have misunderstood you in any way.
