290
Grid Clears when paging
My webgrid clears when paging.  I have read other forum comments regardnig paging issues and tried to implement them without success.
My web page has three objects, dropdownlist, and two calendar controls. the user must select from the first two in order to populate the grid.  The second, ending date, defaults to the current date on Page Load.  If the user choose to changed the ending date they can.
When I select for instance, page 2, the grid clears.  But when I change the beginning date, the records the ought to show for the page is populated to the grid for the correct page.  It appears that the data is in memory for each page in paging, but it is not writing to the grid.
Code
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim bBeginDate As String = lblBeginDate.Text Dim eEndDate As String = lblEndDate.Text
If Not Page.IsPostBack Then
Me.BindData()
btnExportGrid.Visible = False
rdoBtnListExportOptions.Visible = False
Calendar1.SelectedDate = Date.NowCalendar2.SelectedDate = Date.Now
lblEndDate.Text = Calendar2.SelectedDate
lblBeginDate.Text = Calendar1.SelectedDate
ddlLocation.DataBind()
ddlLocation.Items.Insert(0, New ListItem("--Select A Location--", ""))
End If
End Sub
Private Sub BindData()
' Enable paging by default
'Me.ugGridExceptions.DisplayLayout.Pager.AllowPaging = True
Me.ugGridExceptions.DataSource = Me.dsAttendance.Tables("usp_ExcelReport").DefaultView Me.ugGridExceptions.DataBind()
' Disable paging if there aren't enough rows for more than one page
If (Me.ugGridExceptions.DisplayLayout.Pager.PageCount < 2) Then
Me.ugGridExceptions.DisplayLayout.Pager.AllowPaging = False
End If
End Sub
Protected Sub ugGridExceptions_InitializeDataSource(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.UltraGridEventArgs) Handles ugGridExceptions.InitializeDataSource
ugGridExceptions.DisplayLayout.Pager.PageSize = RecordsPerPage
Me.dsAttendance.Tables("usp_Report").DefaultView Me.ugGridExceptions.DataBind()
Me.ugGridExceptions.DisplayLayout.Pager.PageSize = RecordsPerPage Me.ugGridExceptions.DisplayLayout.RowsRange = 100
Me.ugGridExceptions.DisplayLayout.EnableInternalRowsManagement = True
End Sub
Private Sub UltraWebGrid1_PageIndexChanged(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.PageEventArgs) Handles ugGridExceptions.PageIndexChanged
' Set the grid's current page appropriately
ugGridExceptions.DisplayLayout.Pager.CurrentPageIndex = e.NewPageIndex
' Rebind the grid to account for the new page
Me.BindData()
End Sub
Protected Sub UltraWebGrid1_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles ugGridExceptions.InitializeLayout With Me.ugGridExceptions
Me.ugGridExceptions.DisplayLayout.NoDataMessage = "No employee records match your search criteria" 'message no showing up in the grid
.Columns.Clear() 'without columns.clear the first column is column 0 in the grid.
' UserID
.Columns.Add(New Infragistics.WebUI.UltraWebGrid.UltraGridColumn)With .Columns(.Columns.Count - 1)
.Width = 50
.Hidden = False
.Header.Caption = "LocationID"
.IsBound = True
.BaseColumnName = "LocationID"
.Key = "LocationID"
.AllowUpdate = Infragistics.WebUI.UltraWebGrid.AllowUpdate.RowTemplateOnly
End With
' Employee
.Width = 150
.Hidden = False
.Header.Caption = "Employee"
.IsBound = True
.BaseColumnName = "Employee"
.Key = "Employee"
End With
'more columns follow, but did not include
End With
End Sub
  • 290
    Verified Answer
    I got the answer:
    Protected Sub ugGridExceptions_PageIndexChanged(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.PageEventArgs) Handles ugGridExceptions.PageIndexChanged
    BindugGridExceptions()
    End Sub
    AND
    REMOVE
    End Sub
