I am using infragistic 10.3 and ASP.Net 2008. I am having issue in dispaying ultrawebgrid in IE8 compatible mode .Columns are cutting off from right and even horizontal scroll bar is not appearing in some cases and sometimes appears.We are setting the UltraWebGrid width=100% and Columns width in "px" .Tried solution posted on the forum of setting EnableSetCrawel and so on but no success . UltrawebGrid is dispaying properly in IE standard mode but having problem only in IE8 compatible mode.
Hi all,
It has been some time since your posts, however in case you still need assistnace I would be glad to help.
Note that there is a known issue in version 10.3 regarding column misalignment in IE compatibility mode when FixedHeaders are used. The issue has been resolved in 11.1.20111.2084 and 10.3.20103.2199.Upgrading your product versions to the latest service release may therefore resolve the issue.
UltraWebGrid now outdated and as of .NetAdvantage 2011 Volume 2 is no longer included in our product package. I would suggest that you consider switching to the WebDataGrid/WebHieararchicalDataGrid. More information regarding these controls is available at:
http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
Additional samples demonstrating the features of these grids can be found at:http://samples.infragistics.com/aspnet/
Feel free to contact me if you have any questions.
This is an issue for our applications as well. Frustrating.
Not yet.Waiting for infragistic team .Please let me know if you find any solution.
I'm having the same issue and can't find a solution either. I need this grid in a variety of different IE versions and this issue occurs in both IE 9 and IE 8 compatability view. However, we can't dictate to our clients that they have to run IE 8 in non-compatability mode, it's not an acceptable answer to this problem.
Infragistics - please reply and help us!!!
(dollana - did you find a solution yet?)
Infragistic team Please reply.
