Hi, We have design a application contains “XamOutlookBar” and we are adding “OutlookBarGroup” tabs dynamically with “XamTree” inside it. Now I am getting following error after “XamTreeItems” reloaded dynamically and click on other “OutlookBarGroup” Tab in “XamOutlookBar” control. Error: Unhandled Error in Silverlight Application Code: 4004 Category: ManagedRuntimeError Message: System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary. at System.ThrowHelper.ThrowKeyNotFoundException() at System.Collections.Generic.Dictionary`2.get_Item(TKey key) at System.Windows.ResourceManagerWrapper.GetResourceForUri(Uri xamlUri, Type componentType) Code: 0 URL: http://localhost:6722/InfragisticOutlookBarWithTreeTestPage.aspx PSA sample code, and follow the steps to reproduce the above error. 1. Run the application. 2. Select “Dashboard Manager” tab, 3. Click on “Design Dashboards” Refresh button to reload tree items. 4. Select any other outlookbargroup tab and then again select “Dashboard Manager” group tab. 5. It will gives the Unhandled Error. My requirement is to reload the tree items dynamically in xam tree by clicking on refresh button .
HI Asit,
I have created a private support case to give you details about a Development Issue I have logged for this behavior: Development Issue #93983.
Thanks Asit...I am looking into this and will update you again when I have more information.
Thanks for the quick reply.
There is no as such precise steps, you can encounter exeception by click on refresh button multiple times and select another outlookbar tabs and again select the same outlookbar tab from which you click the refresh button or minimize and maximize the outlookbar.
One more thing I want to say that we have one global treeviewItem (_currentTreeItemSimple)variable and asign the selected treeviewItem to that object on selected refresh button's treeviewitem at every refresh button click ( _currentTreeItemSimple = treeItem;).
I have received a couple of different exceptions using your sample and I want to be sure we're testing the same scenario. Please let me know the precise steps to follow from a UI perspective to encounter the exception.
