I downloaded the trial en started programming based on the sample in
"Getting Started with xamMessageBox " The sample is working in VS2010 c#, but not in vb !!!
XamMessageBox.Show("Warning", "This is a warning message", Function() WriteLine("test"), VerticalPosition.Center, _okMessageStyle,New XamMessageBoxCommand("OK", Function() WriteLine("The 'OK' button was pressed.")})) XamMessageBox.Show("Warning", "This is a warning message", Function() WriteLine("test"), VerticalPosition.Center, _okMessageStyle,New XamMessageBoxCommand("OK", Function() WriteLine("The 'OK' button was pressed.")))
the last parameter "New XamMessageBoxCommand("OK", Function() WriteLine("The 'OK' button was pressed.")New XamMessageBoxCommand("OK", Function() WriteLine("The 'OK' button was pressed.") gives an error -> Error 1 Expression does not produce a value.
What is going wrong ???
In vb.net it has to be a function and not a sub. It works !!!
Private Sub WriteLine(message As String) log.Text = messageEnd SubPrivate Function WriteLine(message As String) log.Text = messageEnd Function
Sub
As
String
End
Thanks for reporting it. We'll fix the example in the documentation.
Andres
