I have a XamTree with a large number of XamTreeItems. When I grab an item with the left mouse button and drag it over other items, the items become highlighted. Ordinarily, as I drag from item to item, the item just left becomes unhighlighted and the one entered becomes highlighted. But, with this particular screen, the items that are exited remain highlighted.
Any thoughts on why this is happening and how to remedy it will be greatly appreciated.
Hello jgreene274,
I was looking into your posts and I am not aware of such behavior in the XamTree. If you still have any concerns on the matter could you please create a small test sample, where the issue is reproducible, so I can investigate this.
Thanks in advance.
Never mind. Problem solved. After I create the tree item, I set it's Style property based upon a parameter loaded from a database. In the case of this tree, one of those parameters had not been accounted for and consequently the Style was being set to the default value, which is null. So, for some reason, which I still don't understand, when the Style is set to null for the tree items the above described behavior occurs.
