120
Ultra web Grid excel export is not working.
I am trying to export data from a UltraWebGrid to excel using UltraWebGridExcelExporter.
In C# code behind code i mentioned like this:
this.eExporter.Export(this.uwgAssetSearch,"Asset.xls");
It's throwing following errors:
the type 'Infragistics.Excel.Workbook' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Excel.v10.2, Version=10.2.20102.1011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'
The type 'Infragistics.Excel.Worksheet' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics35.WebUI.Excel.v10.2, Version=10.2.20102.1011, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'.
If i include above said Infragistics35.WebUI.Excel.v10.2 dll, its creating a conflict with existing dll Infragistics35.Web.v10.2.  I am also using WebDataGrid also with excel functionality and its working fine.
