3590
NumericXaxis label shifting after upgrade to 11.1
After I upgrade my project to 11.1 of the Silverlight DV package I noticed that prior to the update I had 5 major axis lines with labels along the x axis that never moved but did update their values as the min/max and interval values of the axis changed. After the upgrade, as the min/max values and interval of the axis changes the very first label and very last label (on the far left and right edges) will seem to shift which one is active. I really do not care which one is available it just needs to stay consistent. My goal was to always have 5 major axis lines, so each time the dataset is updated for any series on the chart I change the the displayed numericxaxis min/max values to the appropriate setting and then based on that range I calculate what the interval needs to be to get only 5 lines. For the past 6 months or so this was fine with 10.3 but now with 11.1 the axis placement seems inconsistent. Why do they not always start on the far left as it used to? Is there a better way to manage this?
