735
Binding collection of series with Datapoint
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4
We are using xamwebChart (line,column and bar charts). We are binding collection of series. Now I want to implement datapoint, how can I do the same.
Following is the code for series binding:
foreach (ControlSeries Series in ListControlSeries)
#region Dynamic Series
       //Setting xCol and yCol and Serice
       Infragistics.Silverlight.Chart.Series MySeries = new Infragistics.Silverlight.Chart.Series();
MySeries.DataMapping = "Value=" + Control.xCol + ";Label=" + Control.yCol;
       MySeries.ChartType = Infragistics.Silverlight.Chart.ChartType.Line;
       MySeries.Label = Series.Value.ToString();
       //Default Animation
       Animation a = new Animation();
       MySeries.Animation = a;
       _XamLineChart.Series.Add(MySeries);
       #endregion
       var dataSource = (from d in doc.Descendants(XML_ELM_GROUP_FIELD).Descendants(XML_ELM_DATA)
where d.Parent.Parent.Parent.Attribute(XML_ATR_CONTROL_NAME).Value == Convert.ToString(_XamLineChart.Tag).Trim() &&
                           d.Parent.Attribute(groupByAttribute).Value == Series.Value
                           select new ChartDataMapper
                                  Value = (double)d.Attribute(xCol),
                                  Name = (string)d.Attribute(yCol).Value
                           }).ToList<ChartDataMapper>();
                _XamLineChart.Series[i].DataSource = dataSource;
                _XamLineChart.Series[i].Label = Series.Value;
                i++;
