I'm using UltraWebGrid v10.3 Also webDataInput and WebDateChooser along with the grid. I'm having a problem with the grid when I open it in Opera, it does not load at all.
So isn't the browser compatibility supported by UltraWebGrid or any other controls? I've to run the grid on Mozilla, Chrome, Opera and Safari importantly. Currently I'm using IE7 and IE8.
Hi AmrutaDeshpande,
Any futher questions pertaining to the UltraWebGrid should be posted in its forum. If you look at the Infragistics Supported Environments page, www.infragistics.com/.../supported-environments.aspx, you will see that these controls are only supported in IE and Firefox. If you would like expanded browser support, you should upgrade your controls to the IG AJAX ASP.NET controls, the WebDataGrid, WebDatePicker, and WebTextEditor.
regards,David Young
