I'm using ver. 10.3 libraries and documentation.
Here's how the Close Method is described:
"Sets the WindowState property to WindowState".
This is not helpful!!!
Is there later documentation that fixes this?
The changes will affect the documentation in our next version release (12.1) because it is generated on version releases only, but the information in the intellisense is fixed.
Regarding my first post in this thread and your post which asked whether the new SR resolved my problem:
I downloaded and ran NetAdvantage_Silverlight_20112.2068_SR.exe. So far as I can tell, it didn't update the documentation at all. Am I overlooking a separate documentation installer?
Hello Joe,
Thanks again.
Thanks. No apology necessary. I should probably be the one apologizing: I just now, after you mentioned it, noticed that the 2031 SR is flagged "[Silverlight 5]".
I think it might have helped if the 2068 SR had been similarly marked with "[Silverlight 4]".
Anyway, I understand now.
Thank you,
Joe
I apologize I haven’t been clear enough. There are different service releases for Silverlight 4 and Silverlight 5 and this is why version 20112.2031 has smaller number than the one you have, because 2031 is for Silverlight 5 and the one you have is for Silverlight 4. Also I can say that the latest service release for Silverlight 4 is 2068 and we will no longer provide SR for Silverlight 4, just for Silverlight 5.
Hope this helps you.
