Style :
<Style x:Key="HeaderCellControlStyle" TargetType="igPrim:HeaderCellControl"> <!--<Setter Property="Margin" Value="-8,0,0,0"></Setter>--> <Setter Property="HorizontalContentAlignment" Value="Stretch"></Setter> <Setter Property="BorderThickness" Value="0" /> <Setter Property="Foreground" Value="Black" /> <Setter Property="VerticalContentAlignment" Value="Center" /> <Setter Property="FontWeight" Value="Bold"></Setter> <Setter Property="Padding" Value="0, 0, 5, 0" /> <Setter Property="FontFamily" Value="Segoe UI" /> <Setter Property="FontSize" Value="9" /> <Setter Property="Template"> <Setter.Value> <ControlTemplate> <Grid> <vsm:VisualStateManager.VisualStateGroups> <vsm:VisualStateGroup x:Name="CommonStates"> <vsm:VisualState x:Name="Normal"> <Storyboard> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellNormalFill" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellNormalBorder" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> </Storyboard> </vsm:VisualState> <vsm:VisualState x:Name="MouseOver"> <Storyboard> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellMouseOverFill" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellMouseOverBorder" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> </Storyboard> </vsm:VisualState> <vsm:VisualState x:Name="Alternate"> <Storyboard> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellAlternateFill" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellAlternateBorder" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> </Storyboard> </vsm:VisualState> </vsm:VisualStateGroup> <vsm:VisualStateGroup x:Name="SelectedStates"> <VisualState x:Name="NotSelected" /> <VisualState x:Name="Selected"> <Storyboard> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellSelectedFill" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> <ObjectAnimationUsingKeyFrames Storyboard.TargetName="GridCellSelectedBorder" Storyboard.TargetProperty="(UIElement.Visibility)"> <DiscreteObjectKeyFrame KeyTime="00:00:00"> <DiscreteObjectKeyFrame.Value> <Visibility>Visible</Visibility> </DiscreteObjectKeyFrame.Value> </DiscreteObjectKeyFrame> </ObjectAnimationUsingKeyFrames> </Storyboard> </VisualState> </vsm:VisualStateGroup> </vsm:VisualStateManager.VisualStateGroups> <Border x:Name="GridCellNormalFill" BorderBrush="White" BorderThickness="{TemplateBinding BorderThickness}" Visibility="Collapsed"> <Border.Background> <SolidColorBrush Color="White"></SolidColorBrush> </Border.Background> </Border>
<Rectangle x:Name="GridCellNormalBorder" Fill="Black" Opacity=".6" Visibility="Collapsed" Margin="0,0,1,0" Height="1" VerticalAlignment="Bottom" /> <Border x:Name="GridCellMouseOverFill" BorderBrush="#FFFFFFCE" BorderThickness="{TemplateBinding BorderThickness}" Visibility="Collapsed"> <Border.Background> <SolidColorBrush Color="#FFFFFFCE" /> </Border.Background> </Border>
<Rectangle x:Name="GridCellMouseOverBorder" Fill="Black" Visibility="Collapsed" Margin="-10,0,1,0" Height="1" VerticalAlignment="Bottom" /> <Rectangle x:Name="GridCellSelectedBorder" Fill="#FFFFFFCE" Visibility="Collapsed" Margin="1,0,1,0" Height="1" VerticalAlignment="Bottom" /> <Border x:Name="GridCellSelectedFill" BorderBrush="#FFB1C5DE" BorderThickness="{TemplateBinding BorderThickness}" Visibility="Collapsed"> <Border.Background> <SolidColorBrush Color="#FFB1C5DE" /> </Border.Background> </Border>
<ContentPresenter VerticalAlignment="{TemplateBinding VerticalContentAlignment}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" Margin="{TemplateBinding Padding}" /> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style>
<ig:XamGrid Name="xgridList" AutoGenerateColumns="False" Grid.Row="1" Grid.Column="0" ColumnWidth="*" HorizontalAlignment="Left" ScrollViewer.HorizontalScrollBarVisibility="Auto" ScrollViewer.VerticalScrollBarVisibility="Auto" ItemsSource="{Binding Path=List}" CellDoubleClicked="XgridList_CellDoubleClicked" SelectedRowsCollectionChanged="XgridList_SelectedRowsCollectionChanged" HeaderStyle="{StaticResource HeaderCellControlStyle}"> <ig:XamGrid.RowSelectorSettings> <ig:RowSelectorSettings Visibility="Collapsed" EnableRowNumbering="False" /> </ig:XamGrid.RowSelectorSettings>
</ig:XamGrid>
Hi Nikolay,
Thanks for reply.
I added SimpleClickableContainer and few more commands and it worked.
I guess you are asking why you can't sort the columns when you click on the header?
It seems that you use a control template from a regular XamGrid's CellControl and just changed the TargetType. The ControlTemplate above has few missing parts, commands and visual states that are specific for the HeaderCellControl.
I would suggest you to take a look at the default control template of the XamGrid and reuse/modify the control template of the HeaderCellControl. Note that the sorting commands are attached to a SimpleClickable container:
... <ControlTemplate TargetType="igPrim:HeaderCellControl"> <igPrim:SimpleClickableContainer ... > <igBase:Commanding.Commands> <igBase:CommandSourceCollection> <ig:XamGridColumnCommandSource CommandType="Select" EventName="SimpleClick"/> <ig:XamGridColumnCommandSource CommandType="SortToggle" EventName="SimpleClick"/> </igBase:CommandSourceCollection> </igBase:Commanding.Commands> ...
HTH
