I use Ultrawebgrid
I want to write a javascript function check on the data grid change or add data.
There is no functional attributes such tests do not? (the same UpdateRowBatch in server)?
Thanks.
I do not use one of the upper jaw. I write a function that is shared (with variable names begin grid).
If I understand correctly the client-side handlers may help you in this case. Check this out : http://help.infragistics.com/NetAdvantage/ASPNET/2011.1/CLR4.0/?page=WebGrid_Client_Side_Events_CSOM.html
