Hi All,
I'm using Version 8.1 and trying to use UltraWebGrid to show some data in my web app. I'm having great deal of problems to auto Expand the groupped items. Please click here to see the screen shot.All I want is when user goes the page they see the records which are groupped and groups are expanded. I searched the forum for 2 days and still found nothing. Here's what I have tried, some sample code: Just so you know below codes don't do anything. It still shows the collapsed view.
Protected Sub UltraWebGrid1_InitializeGroupByRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles UltraWebGrid1.InitializeGroupByRowFor Each row As UltraGridRow In UltraWebGrid1.Rowsrow.Expand(True)NextUltraWebGrid1.ExpandAll(True)End Sub
Protected Sub UltraWebGrid1_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles UltraWebGrid1.InitializeLayoutUltraWebGrid1.Columns(1).IsGroupByColumn = TrueUltraWebGrid1.Columns(1).AllowGroupBy = Infragistics.WebUI.UltraWebGrid.AllowGroupBy.YesUltraWebGrid1.ExpandAll(True)End Sub
Hi Sai,
I got the solution to this problem but this is wat I have used
Protected Sub UltraWebGrid1_GroupColumn(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.ColumnEventArgs) Handles UltraWebGrid1.GroupColumn
FillAdapter("mystoredproc" & NZstr(StartDate.Value.ToString) & ", " & NZstr(EndDate.Value.ToString), SqlConnection1, DA, DS)
Me.UltraWebGrid1.DataBind()
UltraWebGrid1.Rows.Band.ExpandAll()
End Sub
Junaid.
Please set the EXPANDED property in GROUPBYROW to true.I think this will work.
Sai
The user could group by a particular column from the grid. I want to expand all the rows as soon as the user groups by a column. The event which I am using is ultrawebgrid1_groupcolumn. I have tried many things but of no use can someone post a sample code for this problem. The code which I used is (but ths does not work)
