125
Stacking Entries on a Timeline
I have a xamTimeline which is displaying a series of entries with a start date and a duration.  Often, the duration will extend over the start date, and the two areas of the timeline will overlap.  How do I stack the overlapping timelines?
  • 125
    Verified Answer
    I figured this one out on my own, but it required some seriously hacky code to fix.  I ended up having to generate a ControlTemplate at runtime, which forced me to modify part of a string literal and feed it into XamlReader.Load.  You guys should seriously spend some intense effort to make this happen automatically.
    Here's the code for future reference:
       List<DateTimeSeries> seriesList = new List<DateTimeSeries>();
                        seriesList.Add(new DateTimeSeries());
                        seriesList[0].EventSpanStyle = this.Resources["EventSpanStyle"] as Style;
                        seriesList[0].Stroke = new SolidColorBrush(seriesColor);
                        int currentMargin = 0;
                        foreach (ItemType item in ItemsToIterate)
                            DateTimeEntry dateEntry = new DateTimeEntry();
                            dateEntry.Time = ***; // obfuscated values
                            dateEntry.Duration = ***;
                            dateEntry.Title = ***;
                            dateEntry.Details = ***;
                            // Locate a series to add it to
                            int indexToAdd = -1;
                            for (int i = 0; i < seriesList.Count; i++)
                                bool hasOverlap = false;
                                foreach (DateTimeEntry entry in seriesList[i].Entries)
                                    if ((entry.Time <= dateEntry.Time && entry.Time + entry.Duration >= dateEntry.Time) ||
                                        (entry.Time <= dateEntry.Time + dateEntry.Duration &&
                                        entry.Time + entry.Duration >= dateEntry.Time + dateEntry.Duration)) // Check overlap
                                        hasOverlap = true;
                                        break;
                                if (!hasOverlap)
                                    indexToAdd = i;
                                    break;
                            if (indexToAdd != -1)
                                seriesList[indexToAdd].Entries.Add(dateEntry);
                            else
                                // Add a new series
                                currentMargin += 10;
                                Style newStyle = new Style(typeof(EventSpan))
                                        BasedOn = this.Resources["EventSpanStyle"] as Style,
                                ControlTemplate template = (ControlTemplate)XamlReader.Load("<ControlTemplate xmlns:ig=\"http://schemas.infragistics.com/xaml\" xmlns=\"http://schemas.microsoft.com/winfx/2006/xaml/presentation\" xmlns:x=\"http://schemas.microsoft.com/winfx/2006/xaml\" TargetType=\"ig:EventSpan\"><Grid Margin=\"0,2,0,2\"><Rectangle Margin=\"0 " + currentMargin.ToString() + " 0 0\" RadiusX=\"5\" RadiusY=\"5\" Fill=\"{TemplateBinding Fill}\" Height=\"10\" VerticalAlignment=\"Top\" /></Grid></ControlTemplate>");
                                newStyle.Setters.Add(new Setter()
                                    Property = EventSpan.TemplateProperty,
                                    Value = template,
                                seriesList[seriesList.Count - 1].EventSpanStyle = newStyle;
                                seriesList[seriesList.Count - 1].Stroke = new SolidColorBrush(seriesColor);
                                seriesList[seriesList.Count - 1].Entries.Add(dateEntry);
                            if (dateEntry.Time < minValue)
                                minValue = dateEntry.Time;
                            if (dateEntry.Time + dateEntry.Duration > maxValue)
                                maxValue = dateEntry.Time + dateEntry.Duration;
                        foreach (DateTimeSeries series in seriesList)
                            timeline.Series.Add(series);
                        return;
