1750
expand from code
I use the following code (found in this forum)in order to expand dimensions from code :
        void pivotGridMap_LayoutLoaded(object sender, EventArgs e)
            foreach (PivotHeaderCell cell in pivotGridMap.GridLayout.RowHeaderCells)
                if (cell.IsToggleVisible && cell.IsExpanded == false)
                    cell.IsExpanded = true;
                    return;
This works ok if I have only one dimension to expand.
My problem is when I have more than one I get an exception :
"An item with the same key has already been added."
Any ideas ?
Thank you
Dimitris
