I am using xamGrid i have created column throught ColumnLayoutAssigned event
like,
CellTemp.Append("DataTemplate>");
CellTemp.Append("xmlns='http://schemas.microsoft.com/winfx/2006/xaml/presentation' ");
CellTemp.Append("xmlns:x='http://schemas.microsoft.com/winfx/2006/xaml'> ");
CellTemp.Append("<StackPanel Orientation=\"Vertical\">");
CellTemp.Append("<StackPanel Orientation=\"Horizontal\">");
CellTemp.Append(" <Image x:Name=\"imgRestated\" Source=\"../../images/LeftSubMenu_Arrow.png\"></Image>");
CellTemp.Append(" <TextBlock x:Name=\"txtVal1\" Width=\"3\" Height=\"1\"/>");
CellTemp.Append(" <HyperlinkButton x:Name=\"txtValue\" Height=\"12\" Content=\"{Binding SheetName}\" HorizontalAlignment=\"Left\" FontFamily=\"Arial\" FontSize=\"12\" Foreground=\"#0066BE\" IsTabStop=\"False\"/>");
CellTemp.Append(" </StackPanel>");
CellTemp.Append(" </DataTemplate>");
Naw on in mouseover of cell i want to chane the imgRestated image (Show another image on mouseover).
and cell selected event i want to add one image after txtvalue(HyperlinkButton)
please give me the solution.
I apologize i was on vacation.
Anyways, really the way you should be doing this is via a ViewModel. Where you have your Image sources bound to properties of your underlying data object.
That way, when you detect hover or selection, you would simply update the underlying value of the property on your object, and it will be property updated.
-SteveZ
hi
can anyone help me?
