335
It only works the first time
I have the following problem:
I have a grid with a column data and a button, when I click on the button, open a modal window (XamDialogWindow)
When I press the first time opens the modal window: perfect.
After closing the window (pulse de close button).
From that moment, when I press a button again to see the detail of the line, not re-open the modal window.
The code is as follows:
 <ig:XamDialogWindow Name="win" Visibility="Collapsed">
                <ContentControl>
                     <Grid Width="Auto" Height="Auto">
                     all controls ...
 </Grid>
                </ContentControl>
            </ig:XamDialogWindow>
and
on button clik:
win.Width = 700
win.Height = 600
win.StartupPosition = Infragistics.Controls.Interactions.StartupPosition.Center
win.MaximizeButtonVisibility = Windows.Visibility.Collapsed
win.MinimizeButtonVisibility = Windows.Visibility.Collapsed
win.ModalBackgroundEffect = Nothing
win.IsModal = True
win.Visibility = Windows.Visibility.Visible
Version: 2011
thanks
  • 8607
    Hello jcsanchezr,
    Have you tried using the Show() method instead of setting the visibility?
    I made a sample application (in C#, but it's very similar to your code).  Here's my button click method:
            private void button1_Click(object sender, RoutedEventArgs e)
                win.Width = 700;
                win.Height = 600;
                win.StartupPosition = Infragistics.Controls.Interactions.StartupPosition.Center;
                win.MaximizeButtonVisibility = System.Windows.Visibility.Collapsed;
                win.MinimizeButtonVisibility = System.Windows.Visibility.Collapsed;
                win.IsModal = true;
                win.ModalBackgroundEffect = null;
                win.Show();
    Let me know if this works for you.  I can attach my sample project if it would help.
    Elizabeth Albert
    Localization Engineer
