735
Add dynamic Tile pane into Tileview
Normal 0 false false false EN-US X-NONE X-NONE
I am working “XamTileView“.  My requirement is load the 5 dynamic tile pane with controls and set the  control’s ItemSource.
In Xaml that code is running fine.
<ig:TilePane Header="GridPane" TileState="Minimized"  Name="tpGridPane" Key="tpGridPane" Loaded="tpGridPane_Loaded">
                    <ig:TilePane.ContentTemplate>
                        <DataTemplate>
                            <StackPanel>
                                <ig:XamGrid x:Name="xamGrid1" AutoGenerateColumns="False" VerticalAlignment="Stretch" Loaded="xamGrid1_Loaded">
                                    <ig:XamGrid.Columns>
                                        <ig:TextColumn Key="CategoryName" />
                                        <ig:TextColumn Key="Description" />
                                    </ig:XamGrid.Columns>
                                </ig:XamGrid>
                            </StackPanel>
                        </DataTemplate>
                    </ig:TilePane.ContentTemplate>
                </ig:TilePane>
Now as per my dynamic Tile pane creation, i used the following code.
First create the TilePane, DataTemplate and XamContextMenu object.
     TilePane _TilePane = new TilePane();
            DataTemplate _DataTemplate = new DataTemplate();
Then create the object of XamWebChart.
            XamWebChart _XamWebChart = new XamWebChart();
Add the XamWebChart into stackpanel.
            _StackPanel.Children.Add(_XamWebChart);
Now I am unable to bind into data template.
Kindly tell me , what is solution of dynamic tiles add.
Asit Sinha
