Hello Friends,
I am using Infragistics controls in my application first time, and i am facing the following issue.
What I am trying to implement is:
I am using a WebDataGrid and i have kept a ImageButton inside a Template field in the grid. my requirement is onclick of the ImageButton i need to create a panel dynamically with some values and that i am implementing in Itemcommand event.
But the problem i am facing is on click of the Imagebutton the post back is happening which i dont want. Can anyone help me how to stop Postback.
Code in ItemCommand:
protected void WebDataGrid1_ItemCommand(object sender, Infragistics.Web.UI.GridControls.HandleCommandEventArgs e) {
string commandname = e.CommandName; if (commandname == "image") { pan.Visible = true; RowIndex = Convert.ToInt32(e.CommandArgument); PromotionID = WebDataGrid1.Rows[RowIndex].Items[0].Value.ToString(); Status = WebDataGrid1.Rows[RowIndex].Items[2].Value.ToString(); pan.Visible = true; pan.Style.Add(HtmlTextWriterStyle.Width, "100px"); pan.Style.Add(HtmlTextWriterStyle.Height, "100px"); pan.Style.Add(HtmlTextWriterStyle.BorderColor, "black"); pan.Style.Add(HtmlTextWriterStyle.BorderWidth, "1px"); pan.Style.Add(HtmlTextWriterStyle.BorderStyle, "Solid"); pan.Style.Add(HtmlTextWriterStyle.Top, ( 150+(RowIndex*20)+"px").ToString()); pan.Style.Add(HtmlTextWriterStyle.Left, "500px"); pan.Style.Add(HtmlTextWriterStyle.ZIndex, "102px"); pan.Style.Add(HtmlTextWriterStyle.Position, "absolute"); pan.Style.Add(HtmlTextWriterStyle.BackgroundColor, "White"); foreach (KeyValuePair<string,List<string>> pair in dic) { if (Status == pair.Key) { for (int i = 0; i < pair.Value.Count; i++) { LinkButton lnkbtn = new LinkButton(); lnkbtn.Text = pair.Value[i].ToString() +"</br>"; lnkbtn.ID = "LinkButton" +( RowIndex + 1); lnkbtn.PostBackUrl="About.aspx? PromotionID=" +PromotionID; pan.Controls.Add(lnkbtn); } } } Form.Controls.Add(pan); // RaiseBubbleEvent(this, e); // not working // e.Handled = true; } Please help me out....
Thanks & Regards,
Joyanta
Hi Joyanta,
this is expected behavior. Put the grid inside update panel or create this panel on the client.
