1060
Multiple (dynamic) Series in Data Chart.
I have a requirements to create a data chart which eventually have 4 (confirmed: not more not less) series.
  • 2 Line Series
  • 1 Column Series
  • 1 Range Area Series.
All these series must be created dynamically (i.e. their X-Axis and Y-Axis points) based on some calculation on my DTO object. Previously I successfully created a chart using xamWebChart which have one line series and 1 column series, as described here. Now my requirement is to add Range Area series in it as shown in this images.
I found that xamDataChart only have this "Range Area Series" but I don't know how can I create datapoints dynamically in it. Here is the some sample code which I did previously for creating xamWebChart. I will appreciate if someone help me to give any idea how can I achieve my requirements. If I can also add "Range Area Series" (or something similar to requirements) then it will be awesome.
/*************************************Create Series and Axes of chart*********************/
/* minyear and maxyear have number of points to be created.
        theChart.Series.Clear();
            theChart.Axes.Clear();
            int mYear = minYear;
            Series lineSeries = new Series { ChartType = ChartType.Line, AxisX = "x1", AxisY = "y1" };
            Series columnSeries = new Series { ChartType = ChartType.Column, AxisX = "x1", AxisY = "y2", Stroke = new SolidColorBrush(Colors.Transparent), Opacity = 0.2, UseDataTemplate = true };
            columnSeries.DataPointStyle = (Style)this.Resources["columnSeriesPointStyle"];
            LinearGradientBrush linBrush = new LinearGradientBrush();
            linBrush.Opacity = 0.2;
            linBrush.GradientStops.Add(new GradientStop { Color = Infragistics.ColorConverter.FromString("#FFBF00") });
            columnSeries.Fill = linBrush;
            while (mYear <= maxYear)
                lineSeries.DataPoints.Add(new DataPoint(0, mYear.ToString()) { Marker = new Marker { Type = MarkerType.None } });
                columnSeries.DataPoints.Add(new DataPoint(0));
                mYear = mYear + 1;
            Axis x1Axis = new Axis { AxisType = AxisType.PrimaryX, Name = "x1" };
            x1Axis.MajorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            x1Axis.MinorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            Axis y1Axis = new Axis { AxisType = AxisType.PrimaryY, Name = "y1" };
            y1Axis.MajorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            y1Axis.MinorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            Axis y2Axis = new Axis { AxisType = AxisType.SecondaryY, Name = "y2", Minimum = 0, Maximum = 1, Unit = 1, AutoRange = false, Visibility = Visibility.Collapsed };
            y2Axis.MajorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            y2Axis.MinorGridline = new GridlineGroup { Visibility = Visibility.Collapsed };
            theChart.Axes.Add(x1Axis);
            theChart.Axes.Add(y1Axis);
            theChart.Axes.Add(y2Axis);
            theChart.Series.Add(lineSeries);
            theChart.Series.Add(columnSeries);
/***************************************Add Chart points and Data*************************/
Axis y1Axis = theChart.Axes.FirstOrDefault<Axis>(axis => axis.AxisType == AxisType.PrimaryY);
Series lineSeries = theChart.Series.FirstOrDefault<Series>(series => series.ChartType == ChartType.Line);
int seriesDataPointInedex = 0;
    lineSeries.DataPoints[seriesDataPointInedex].Value = valueofPoint;
    seriesDataPointInedex = seriesDataPointInedex + 1;
        mYear = mYear + 1;
Series columnSeries = theChart.Series.FirstOrDefault<Series>(series => series.ChartType == ChartType.Column);
DataPoint dp = columnSeries.DataPoints[ddlYear.SelectedIndex];
dp.Value = 1;
Kindly help.
