10
64Bit conversion
We are converting our 32Bit webapplication as 64Bit application which is using Infragistics ultra webgrid6.1,Date chooser6.1(License version).
1.Is ultra webgrid6.1 compatibility with 64Bit ?
2. We tried to use the same 6.1 dll in 64Bit application,We did't get any error while recompileing,but We found a problem at
   There is a check box inside a web grid which returns always false even checked or unchecked... Note : It is working fine in 32 Bit application.
Now we have downloaded the latest version 8.1 and use it in our 64-bit application but the problem still persists.The checkbox that is placed in the grid seems to be not working when a new row added but working when modified the existing rows. Can you please clarify us why this is happened as it stops us from working.
Thanks in advance
Chandru.J
