I can see that it's very easy to set the SelectedTime property in xaml, but how do I set the value in code behind?
<igtl:XamTimeline x:Name="xamTimeline" Width="1000" Height="250" > <igtl:XamTimeline.Axis > <igtl:NumericTimeAxis Minimum="1" Maximum="27" AutoRange="True" ShowLabels="True" Unit="1" SelectedTime="5" /> </igtl:XamTimeline.Axis> <igtl:XamTimeline.PreviewAxis> <igtl:PreviewAxis ShowLabels="True" /> </igtl:XamTimeline.PreviewAxis> <igtl:XamTimeline.EventTitleLayoutSettings> <igtl:EventTitleLayoutSettings HorizontalOffset="5" VerticalOffset="5" Enabled="True" /> </igtl:XamTimeline.EventTitleLayoutSettings></igtl:XamTimeline>
Sincerely,
Krasimir
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
Here is how you can set the selected time from code behind:
((NumericTimeAxis)xamTimeline.Axis).SelectedTime = 5;
