I have a simple autocompleting editable dropdown. It does not accept umlauts (äöåü) from keyboard. If I copy-paste the character, then it will be entered and autocompleted.
Selecting items with keyboard is also broken, one can't select an item without writing a letter first. The letter also must be the first one of entry, if one has "Contains" comparision operator, you can't select any item with keybord.
Setup:
Loaded += (s, e) => {
xamAutoComp.DataContext = (from str in new[] { "auli", "ääni", "paakayttaja", "pääkäyttäjä" } select new SWrap { Data = str }).ToList(); };
public class SWrap { public string Data { get; set; } }
xaml:
<ig:XamComboEditor
Name="xamAutoComp" Width="160" Height="22"
ItemsSource="{Binding}"
CustomValueEnteredAction="Allow"
EmptyText="Empty"
IsEditable="True"
AutoComplete="True"
DisplayMemberPath="Data"
AllowFiltering="True">
<ig:XamComboEditor.CustomItemsFilter>
<ig:ItemsFilter>
<ig:ItemsFilter.Conditions>
<ig:ComparisonCondition Operator="Contains" />
</ig:ItemsFilter.Conditions>
</ig:ItemsFilter>
</ig:XamComboEditor.CustomItemsFilter>
</ig:XamComboEditor>
these seem like bugs. I have created a support case on your behalf so you could track the progress on the issues - Case ID: CAS-67495-96X5CT.
The internal development items are #79251(Selecting an item using "Enter" key is not working when CustomValueAction is set to Allow) and #79255(XamComboEditor does not accept umlaut(äöåü) symbols when entered through the keyboard).
Thanks for your feedback. Please let me know if you have any further questions.
