Hello!
I'm trying to hide columns in a multi header. But the behavior of the grid for me unpredictable. Does this principle the possibility? Below describe the way I am trying to use it.
I formed the following table:
Trying to hide the column by specifying its name.
1. Hide the column "name"
2. Showing the column "name"
3. Again, hide the column name - as a result everything is in order.
All subsequent manipulations with any columns are correct. I would like to clarify that I'm doing wrong. The source code of algorithms, which is hiding, is presented below.
*.cs:
using System;using System.Collections.Generic;using System.Linq;using System.Xml.Linq;using System.Web;using System.Web.UI;using System.Diagnostics;using System.Data;using Infragistics.WebUI.WebDataInput;using System.Xml;using Infragistics.Documents.Graphics;using Infragistics.Web.UI.GridControls;using Infragistics.WebUI.UltraWebGrid;using System.Collections;using System.IO;using System.Drawing;using System.Reflection;namespace WebApplication1{ public partial class MyPage : Page { /// <summary> /// Initial setting headlines /// </summary> public HeadersCollection OrignHedersOptions { get { return this.Session["HeadersCollection"] as HeadersCollection; } set { this.Session["HeadersCollection"] = value; } } protected void Page_Load(object sender, EventArgs e) { DataTable dt = "People"; dt.Columns.Add("index", typeof(int)); dt.Columns.Add("name", typeof(string)); dt.Columns.Add("sex", typeof(bool)); for (int i = 0; i <= 10; i++) { dt.Rows.Add(new object[] { i, "Tom" + i, true }); } UltraWebGrid1.DataSource = dt; if (!this.IsPostBack) { UltraWebGrid1.DataBind(); } } protected void UltraWebGrid1_InitializeLayout(object sender, LayoutEventArgs e) { foreach (UltraGridColumn c in e.Layout.Bands[0].Columns) { c.Header.RowLayoutColumnInfo.OriginY = 1; } ColumnHeader A = new ColumnHeader(true); A.Caption = "People"; A.RowLayoutColumnInfo.OriginY = 0; A.RowLayoutColumnInfo.SpanX = 3; A.Key = "People"; e.Layout.Bands[0].HeaderLayout.Add(A); OrignHedersOptions = e.Layout.Bands[0].HeaderLayout.CopyFrom(e.Layout.Bands[0].HeaderLayout); } void MakeHiddenColumn(UltraWebGrid ultraWebGrid, string key, HeadersCollection OrignHedersOptions) { if (!(ultraWebGrid.Bands[0].Columns.FromKey(key).Hidden)) { ultraWebGrid.Bands[0].Columns.FromKey(key).Hidden = true; foreach (ColumnHeader origHead in OrignHedersOptions) { if ((origHead.RowLayoutColumnInfo.SpanX > 1) && (origHead.RowLayoutColumnInfo.OriginX + origHead.RowLayoutColumnInfo.SpanX - 1 >= ultraWebGrid.Bands[0].Columns.FromKey(key).Index)) { foreach (ColumnHeader curHead in ultraWebGrid.Bands[0].HeaderLayout) { if (curHead.Key == origHead.Key) { if (origHead.RowLayoutColumnInfo.OriginX == ultraWebGrid.Bands[0].Columns.FromKey(key).Index) { curHead.RowLayoutColumnInfo.OriginX = ultraWebGrid.Bands[0].Columns.FromKey(key).Index + 1; } curHead.RowLayoutColumnInfo.SpanX--; } } } } } } void MakeAnHiddenColumn(UltraWebGrid ultraWebGrid, string key, HeadersCollection OrignHedersOptions) { if (ultraWebGrid.Bands[0].Columns.FromKey(key).Hidden) { ultraWebGrid.Bands[0].Columns.FromKey(key).Hidden = false; foreach (ColumnHeader origHead in OrignHedersOptions) { if ((origHead.RowLayoutColumnInfo.SpanX > 1) && (origHead.RowLayoutColumnInfo.OriginX + origHead.RowLayoutColumnInfo.SpanX - 1 >= ultraWebGrid.Bands[0].Columns.FromKey(key).Index) && (origHead.Caption != key)) { foreach (ColumnHeader curHead in ultraWebGrid.Bands[0].HeaderLayout) { if (curHead.Key == origHead.Key) { if (origHead.RowLayoutColumnInfo.OriginX == ultraWebGrid.Bands[0].Columns.FromKey(key).Index) { curHead.RowLayoutColumnInfo.OriginX = ultraWebGrid.Bands[0].Columns.FromKey(key).Index; } curHead.RowLayoutColumnInfo.SpanX++; } } } } } } /// <summary> /// Hidden Column /// </summary> protected void WebImageButton3_Click(object sender, ButtonEventArgs e) { this.MakeHiddenColumn(this.UltraWebGrid1, WebTextEditor1.Text, this.OrignHedersOptions); } /// <summary> /// Show Column /// </summary> protected void WebImageButton4_Click(object sender, ButtonEventArgs e) { this.MakeAnHiddenColumn(this.UltraWebGrid1, WebTextEditor1.Text, this.OrignHedersOptions); } }}
*.aspx:
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="MyPage.aspx.cs" Inherits="WebApplication1.MyPage" %><%@ Register Assembly="Infragistics4.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %><%@ Register Assembly="Infragistics4.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI" TagPrefix="ig" %><%@ Register Assembly="Infragistics4.WebUI.WebDataInput.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.WebDataInput" TagPrefix="igtxt" %><%@ Register assembly="Infragistics4.WebUI.UltraWebGrid.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %><%@ Register assembly="Infragistics4.WebUI.UltraWebGrid.DocumentExport.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid.DocumentExport" tagprefix="igtbldocexp" %><%@ Register assembly="Infragistics4.WebUI.UltraWebGrid.ExcelExport.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid.ExcelExport" tagprefix="igtblexp" %><%@ Register assembly="Infragistics4.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.EditorControls" tagprefix="ig" %><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head runat="server"> <title></title></head><body> <form id="form1" runat="server"> <div> <igtxt:WebImageButton ID="WebImageButton3" runat="server" onclick="WebImageButton3_Click" Text="Hidden Column"> </igtxt:WebImageButton> <igtxt:WebImageButton ID="WebImageButton4" runat="server" onclick="WebImageButton4_Click" Text="Show Column"> </igtxt:WebImageButton> <ig:WebTextEditor ID="WebTextEditor1" runat="server" Text="index"> </ig:WebTextEditor> <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Height="647px" Width="448px" oninitializelayout="UltraWebGrid1_InitializeLayout"> <displaylayout allowcolsizingdefault="Free" allowcolumnmovingdefault="OnServer" allowdeletedefault="Yes" allowsortingdefault="OnClient" allowupdatedefault="Yes" autogeneratecolumns="False" bordercollapsedefault="Separate" headerclickactiondefault="SortMulti" name="UltraWebGrid1" rowheightdefault="20px" rowselectorsdefault="No" selecttyperowdefault="Extended" stationarymargins="Header" stationarymarginsoutlookgroupby="True" tablelayout="Fixed" version="4.00" viewtype="OutlookGroupBy" ColFootersVisibleDefault="Yes"> <framestyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid" borderwidth="1px" font-names="Microsoft Sans Serif" font-size="8.25pt" height="647px" width="448px"> </framestyle> <pager minimumpagesfordisplay="2"> <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </PagerStyle> </pager> <editcellstyledefault borderstyle="None" borderwidth="0px"> </editcellstyledefault> <footerstyledefault backcolor="LightGray" borderstyle="Solid" borderwidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </footerstyledefault> <headerstyledefault backcolor="LightGray" borderstyle="Solid" horizontalalign="Left"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </headerstyledefault> <rowstyledefault backcolor="Window" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" font-names="Microsoft Sans Serif" font-size="8.25pt"> <padding left="3px" /> <borderdetails colorleft="Window" colortop="Window" /> </rowstyledefault> <groupbyrowstyledefault backcolor="Control" bordercolor="Window"> </groupbyrowstyledefault> <groupbybox> <boxstyle backcolor="ActiveBorder" bordercolor="Window"> </boxstyle> </groupbybox> <addnewbox hidden="False"> <boxstyle backcolor="Window" bordercolor="InactiveCaption" borderstyle="Solid" borderwidth="1px"> <borderdetails colorleft="White" colortop="White" widthleft="1px" widthtop="1px" /> </boxstyle> </addnewbox> <activationobject bordercolor="" borderwidth=""> </activationobject> <filteroptionsdefault FilterUIType="HeaderIcons" AllowRowFiltering="OnServer"> <filterdropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px" height="300px" width="200px"> <padding left="2px" /> </filterdropdownstyle> <filterhighlightrowstyle backcolor="#151C55" forecolor="White"> </filterhighlightrowstyle> <filteroperanddropdownstyle backcolor="White" bordercolor="Silver" borderstyle="Solid" borderwidth="1px" customrules="overflow:auto;" font-names="Verdana,Arial,Helvetica,sans-serif" font-size="11px"> <padding left="2px" /> </filteroperanddropdownstyle> </filteroptionsdefault> </displaylayout> <bands> <igtbl:UltraGridBand> <Columns> <igtbl:UltraGridColumn BaseColumnName="index" DataType="System.Int32" Key="index"> <Header Caption="index"> </Header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="name" Key="name"> <Header Caption="name"> <RowLayoutColumnInfo OriginX="1" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="1" /> </Footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="sex" DataType="System.Boolean" Key="sex" Type="CheckBox"> <Header Caption="sex"> <RowLayoutColumnInfo OriginX="2" /> </Header> <Footer> <RowLayoutColumnInfo OriginX="2" /> </Footer> </igtbl:UltraGridColumn> </Columns> <addnewrow view="NotSet" visible="NotSet"> </addnewrow> </igtbl:UltraGridBand> </bands> </igtbl:UltraWebGrid> <ig:WebScriptManager ID="WebScriptManager1" runat="server"> </ig:WebScriptManager> </div> </form></body></html>
I hope that you will help in resolving this issue. I would be glad if you suggest another solution to this problem. Thank you!
Thank you. Problem solved.
