Normal 0 false false false MicrosoftInternetExplorer4
Hello
Is this possible to set minimum column width without using ColWidthDefault. We made WebUltraGrid width 100%. It is necessary that the column widths dynamically distributed across the width of the grid, but the width of the column remained at least the minimum width.
Thank you
Hello.
Thank you for your reply.
All clear.
Hello Sergey,
Thank you for the update
In this scenario I recommend you handling the BeforeColumnSizeChange client side event:
http://community.infragistics.com/forums/p/12693/47928.aspx#47928
<ClientSideEvents BeforeColumnSizeChangeHandler="UltraWebGrid1_BeforeColumnSizeChangeHandler" />
function UltraWebGrid1_BeforeColumnSizeChangeHandler(gridName, columnId, width) {
//Add code to handle your event here.
if ((width < 300) && (igtbl_getColumnById(columnId).Key == 'ID')) {
return true;
Please let me know if you need further assistance regarding this.
Good afternoon. Thank you for your reply. For TableLayout = Fixed column is compressed, with a decrease in the browser window. Maybe there are other options?
I can suggest you using the CustomRules of the CellStyle in order to set the min-width
<igtbl:UltraGridColumn BaseColumnName="ID" Key="ID" AllowResize="Free" >
<Header Caption="ID">
</Header>
<CellStyle CustomRules="min-width: 300px;"></CellStyle>
</igtbl:UltraGridColumn>
