I am getting the following javascript error when I run the ultrawebgrid with IE9.
I have read that 10.3 might solve the issue.
Has anyone else had the issue and does 10.3 fix the problem?
Graham O'RileyNetdocs Plc
Hi Graham,
It has been some time since your post, however in case you still need assistance I would be glad to help.
The following thread discusses a very similar scenario to yours:
https://es.infragistics.com/community/forums/f/ultimate-ui-for-asp-net/54943/ultrawebgrid-issues-in-only-ie9
UltraWebGrid's issues in question with IE9 should be resolved with version 10.3.20103.2134.
Please note that the UltraWebGrid control is now outdated and as of .NetAdvantage 2011 Volume 2 is no longer included in our product package. I would suggest that you consider switching to the WebDataGrid/WebHieararchicalDataGrid. More information regarding these controls is available at:
http://help.infragistics.com/Doc/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
Additional samples demonstrating the features of these grids can be found at:https://es.infragistics.com/samples/aspnet/
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.https://es.infragistics.com/support
