I am using XamWebGrid 10.3. I have code that use to hide some data from the grid, the reason this is done is that we have custom code to pull specialized sum data from the database. I am using the CellControlAttached event to hide the row based on criteria, which is if it GrandTotalInd. When the page load initially it works, but if I change parameters it will give me an error, which I detail below.
e.Cell.Row.Height =
new RowHeight(0);
however I get an error when having this code Value cannot be infinite or NaN. below you will find the full error:
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.2; .NET4.0C; .NET4.0E; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729)
Timestamp: Tue, 17 May 2011 06:46:25 UTC
Message: Unhandled Error in Silverlight Application
Code: 4004
Category: ManagedRuntimeError
Message: System.ArgumentException: Value cannot be infinite or NaN.
Parameter name: System.Windows.CustomDependencyProperty
at System.Windows.Controls.Primitives.RangeBase.OnMaximumPropertyChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.RaisePropertyChangeNotifications(DependencyProperty dp, Object oldValue, Object newValue)
at System.Windows.DependencyObject.UpdateEffectiveValue(DependencyProperty property, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, ValueOperation operation)
at System.Windows.DependencyObject.SetValueInternal(DependencyProperty dp, Object value, Boolean allowReadOnlySet)
at System.Windows.DependencyObject.SetValue(DependencyProperty property, Double d)
at Infragistics.Controls.Grids.Primitives.RowsPanel.UpdateScrollInfo(Int32 totalRowCount)
at Infragistics.Controls.Grids.Primitives.RowsPanel.ArrangeOverride(Size finalSize)
at System.Windows.FrameworkElement.ArrangeOverride(IntPtr nativeTarget, Single inWidth, Single inHeight, Single& outWidth, Single& outHeight)
Line: 55
Char: 13
Code: 0
A ValueConverter implements the IValueConverter interface from MSFT. Attached is sample that demonstrates it's usage.
Hi Darrell,
Thanks for suggestion, can you give me a simple example to use valueconverter or related link
The FormatString is just what is going to get given eventually to a ToString on the value, and to my knowledge there isn't a format string that is going to convert NaN to a value.
You could add a ValueConverter to the column which can process your data and convert your NaNs to zeros or empty strings.
Hi Stevez,
if we are binding xamgrid with List of objects and have following column bind to some double type property:
<ig:TextColumn Key="MyDouble" HeaderText="My Double" FormatString="{}{0:0.00}" HorizontalContentAlignment="Right" />
It is working fine and even do not crash on NAN vlaues, but it shows NaN which do not looks good, what we can do to show either empty or cutom value say dash (-).
Thank you Stephen,
this worked perfectly and simplified my code considerable.
I only had to struggle a bit to make the decoding of 'Records' generic as my datagrid's ItemsSource is changing at runtime.
Regards
Jorvart
