Hi There,
I have created a pie chart with transparent background on a user control, the user control also has transparent background and the main page has a grey background. When I add the pie chart control the ScrolViewer in the grid panel sets its colour to white rather than transparent.
I have tried to see why this might be happening but I can't seem to find any reason?
Is there something I am doing wrong, or is there anyway to force the ScrollViewer to be transparent?
Thanks in advance
I see, however this is not something I have dealt with before and since I cannot reproduce it, I am not sure if can be of much assistance.
Pease let me know if I can help in any way.
Hi Peter,
I have tried to reproduce this issue with a simple project, I have even set it up so it has the same layers behind the pie chart, however I can't reproduce it and unfortunately I cannot send you the project where I am having problems.
I'm sure we can work around it by traversing the ui elements and checking the background brush, I just thought there may have been something that you have come across before.
I have been reading through your description and I cannot think of a reason this could be happening.
Would it be possible for you to provide me with a sample project that reproduces this, so I can investigate it further.
