390
Our requirement is to show a open hand cursor while hovering over XamMap and while panning a XamMap, show a dragging hand cursor
“Our requirement is to show a open hand cursor while hovering over XamMap and while panning a XamMap, show a dragging hand cursor. There has been quite a few blog posts on how to create custom cursors in Silverlight, but We felt some of them were very limited or not very re-useable, or required you to put the cursor in the layout and put restrictions on your layout (like for instance requiring you to use a Canvas as parent for your cursor). One of the approach we used out here: You “disable” the cursor on your XamMap by setting xamMap.Cursor = Cursors.None. Next you move a custom UIElement(open hand image) around on top of your layout which represents your custom cursor. But with this approach we are facing two main problems: 1. Since we are using a Popup to hold drag cursor image, Sometimes when the popup opens it stops dragging completely. 2. While zooming a XamMap,it stops zooming intermittently. This is because we are opening this popup on "xamMap_WindowRectChanged" event and this event is called while panning as well as zooming.”
  • 3255
    Suggested Answer
    posted in reply to bharath
    Hi bharath,
    Please find attached a sample application (). To run it just add Infragistics' dlls. XamMap's WindowAnimationMode is left to its default value.
    Please let me know if that works for you.
    Ivan Kotev
  • 3255
    Hi bharath,
    Unfortunately I don't think there is an easy way to achieve this behaiour in Silverlight. I have tried another approach - to use SymbolElement for the mouse cursor. The following sample uses 2 MapLayers, one for the open hand and another fot the dragging hand cursor. A single SymbolElement is added in each layer to represent cursor position. On XamMap's MapMouseMove the SymbolElement's SymbolOrigin value is updated. There are a couple of issues although. XamMap's elements cannot be hovered and XamMap's WindowAnimationMode is set to MapWindowAnimationMode.None.
    XAML:
    <Maps:XamMap x:Name="xamMap" Width="800" Height="600">
     <Maps:MapNavigationPane igControls:XamDock.Edge="InsideRight" />
     <Maps:XamMap.Layers>
      <Maps:MapLayer Imported="MapLayer_Imported">
       <Maps:MapLayer.Reader>
        <Maps:ShapeFileReader Uri="Shapefiles/world/world"  DataMapping="Caption=CNTRY_NAME"/>
       </Maps:MapLayer.Reader>
      </Maps:MapLayer>
      <Maps:MapLayer>
       <Maps:MapLayer.ValueTemplate>
        <DataTemplate>
         <Image Source="hand1.png">
         </Image>
        </DataTemplate>
       </Maps:MapLayer.ValueTemplate>
      </Maps:MapLayer>
      <Maps:MapLayer>
        <DataTemplate>
         <Image Source="hand2.png">
         </Image>
        </DataTemplate>
      </Maps:MapLayer>
     </Maps:XamMap.Layers>
    </Maps:XamMap>
    Code behind:
    public partial class MouseCursorTest : Page
     private SymbolElement _hand1;
     private SymbolElement _hand2;
     private SymbolElement _currentHand;
     private double _previousWindowZoom;
     private Point _position;
     public MouseCursorTest()
      InitializeComponent();
      xamMap.WindowAnimationMode = MapWindowAnimationMode.None;
      xamMap.MapMouseMove += (sender, e) =>
       if (_currentHand != null)
        _position = e.Position;
        _currentHand.SymbolOrigin = xamMap.Viewport.RootCanvas.RenderTransform.Inverse.Transform(_position);
      xamMap.WindowRectChanged += (sender, e) =>
               if (_previousWindowZoom == xamMap.WindowZoom)
                xamMap.Layers[1].IsVisible = false;
                xamMap.Layers[2].IsVisible = true;
                _currentHand = _hand2;
               else
                xamMap.Layers[1].IsVisible = true;
                xamMap.Layers[2].IsVisible = false;
                _currentHand = _hand1;
                _previousWindowZoom = xamMap.WindowZoom;
      xamMap.MapMouseLeftButtonUp += (sender, e) =>
     private void MapLayer_Imported(object sender, MapLayerImportEventArgs e)
      if (e.Action == MapLayerImportAction.End)
       var origin = new Point(xamMap.Layers[0].WorldRect.Left + xamMap.Layers[0].WorldRect.Width / 2.0,
               xamMap.Layers[0].WorldRect.Top + xamMap.Layers[0].WorldRect.Height / 2.0);
       _hand1 = new SymbolElement { SymbolOrigin = origin, SymbolType = MapSymbolType.None, IsClickable = false, IsSensitive = false };
       _hand2 = new SymbolElement { SymbolOrigin = origin, SymbolType = MapSymbolType.None, IsClickable = false, IsSensitive = false };
       xamMap.Layers[1].LayerName = "Layer 1";
       xamMap.Layers[1].WorldRect = xamMap.Layers[0].WorldRect;
       xamMap.Layers[1].Elements.Add(_hand1);
       xamMap.Layers[2].LayerName = "Layer 2";
       xamMap.Layers[2].WorldRect = xamMap.Layers[0].WorldRect;
       xamMap.Layers[2].Elements.Add(_hand2);
    Ivan Kotev
