I am getting this error when I attempt to build my project (I am using Data Visualization for Silverlight). I had all of this working but I had to rebuild my machine. Since then, I have been unable to get it to compile.
Here is the error:
"Could not load file or assembly 'InfragisticsSL4.v10.3, Version=10.3.20103.1006, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb' or one of its dependencies. The system cannot find the file specified."
I need to point out that I have modified the source code (I added a class to the XamMap project). Everything in the DV solution builds fine, though. I copied the resulting binaries to the proper place under Program Files (I think).
I have all of the correct refrences in my project, but I still get this error.
I am using Visual Studio 2010.
Any ideas?
Dear Michael,
I am having the same problem can you guide me step by step. I am unable to find any reference for infragistics in the references of client. Also i am unable to find any DLL's too.
Farhan
I finally figured this out for those of you that may run into this in the future.
Since I altered the source code, I had to copy ALL of the newly built DLLs over to the Program Files\Infragistics folders. Once I did that, I had to go back into VS and do some odd things.
The first thing I did was removed all of the Infragistices references (I am using XamDataChart, XamGauge, XamPivotGrid, XamMap, and DtatVisualization and InfragisticsSL4.v10.3).
I then closed Visual Studio.
I opened Visual Studio again and attempted a build (without adding the references). It failed. I then added the references by navigating to "Program Files\Infragistics" and pulled the DLLs from there.
I then rebuilt. Got a few errors about a missing reference for some of the controls. This is where it gets strange. I had to switch to Release mode, rebuild, then switch back to debug mode. Once I did that, all controls built except for one - the XamMap (which is the DLL that I altered). All I had to do was load the XAML for the page that I used the map in, remove the actual <ig:XamMap/> tag and all of its contents, and then rebuild. Of course, it failed once more. So I added the <ig:XamMap/> tag back and rebuilt.
It worked.
I now have a configuration that works. I hope that some of this will be of use to anyone with this problem in the future.
