1750
MDX Calculated member / Named set using Expression builder in XamPivotGrid
Can I add calculated members in the XamPivotGrid by using an expression builder ?
My need is to create an simple expression builder that for example will add two measures in order to create a simple new calculated member.
Can I add this new field in the XamPivotGrid's field's list ?
If yes is there an example?
Dimitris
(if this can be done in 2011.1 please give some hints about how I can achieve it)
