I want to have a client side handler to be fired when I click a node in the UltraWebTree.In the onPreRender function in C# I have put
ultraWebTree.ClientSideEvents.NodeClick = "conf.NodeClickHandler";
The conf.NodeClickHandler is now only called when I do a right mouse click and _not_ on a left mouse click.I see that the events get through to WebResource.axd/igtree_fireEvent but eventObj is only filled when I do a right click.
Does anyone know what is going on?
Hello greale,
Let me know if you have further questions.
The client events for the “UltraWebTree” should be declared in the tree “.aspx” code:
<ClientSideEvents NodeClick="NodeClick"></ClientSideEvents>
Look at the following sample to view usage of some “UltraWebTree” Client-Side events - http://samples.infragistics.com/2008.3/WebFeatureBrowser/contents.aspx?showCode=True&t=WebTree/treeclientsideevents/TreeClientSideEvents.aspx~srcview.aspx?path=../webfeaturebrowservb/WebTree/treeclientsideevents/TreeClientSideEvents.src~srcview.aspx?path=WebTree/treeclientsideevents/TreeClientSideEvents.src
Let me know if you need further assistance with this question.
