I am binding the xamDataSelector with a FlatData Source. After providing the FlatDataSource with the list of Cubes which i want to display, i am not able to see any of the cubes. Can you please let me know where i am going wrong.
Following is the code:
dataSource =
dataSource.ConnectionSettings =
lstCube)
cubeMetaData.DisplayName = e.Name;
cubeMetaData.DataTypeFullName = e.Name;
dataSource.CubesSettings.Add(cubeMetaData);
PivotGrid.DataSource = dataSource;
PivotDataSelector.DataSource = dataSource;
Thanks,Sachin.
Hi Sachin,
Looks like I mistyped my last response. The samples I wanted to recommend are the “FlatDataSource(XAML)” and “FlatDataSourceCodeBehind)”.
Let me know if you have further questions.
You need to define the hierarchies and measures which you can do in xaml or in code behind.
This document explains how to go about it.
http://help.infragistics.com/NetAdvantage/DV/2010.3/CLR4.0/?page=xamPivotGrid_US_Assigning_Hierarchies_And_Measures.html
There are samples in the Silverlight DV feature browser in the Basic section, “FlatDataSource(XAML)” and “FlatDataSource(XAML)”, which should be helpful to you.
