http://news.infragistics.com/forums/p/13141/281906.aspx
The problem:
AutoComplete is turned on (and should stay turned on) but prevents Users from changing the text after autocompleting the text.
After you log in go to My IG and then to My Support Activity.
You could try this link.
HTH
Thank you!
EDIT: Where can i look after the mentioned support ticket?
sorry about the previous post - my mistake.
I managed to reproduce the issue now and it seams like a bug. I have created a support ticket on your behalf CAS-64529-7VSX3M. The internal bug id is 73924.
Hey,
like i wrote try to commit "2" not "2.5". My version is 10.3.20103.2117.
Hi UgaAga,
I run the solution you supplied in your previous post and had no problems committing "2.5". I run your solution with 10.3 RTM assemblies as well as with the Latest(March) Service Release and had no luck in reproducing the issue.
Could you tell the exact build number so I can run your solution against it.
P.S. It is good when editing a post to mark the Edited section - especially when some time has passed after the time of the original post.
