Our grid is Infragistics UltraWebGrid 7.1.
We could not find any way to change each column's footer cell style. Every column has same footer style with each other.
Each column has to get a different footer cell style.
Is there any way to achive this?
C# or javascript samples would be appreciated.
Note : 1. The reason for this request is this : We are using an image column and i dont want to see the image on the column's footer cell. So i will clear all the images on the columns which i've already knew that they are image colıumn.
Note 2 : Attached image shows a problematic grid footer.
Hello hsevand,
you will have to upgrade to newer version to get support for the newer browsers.For more information please see Supported Environments: https://es.infragistics.com/support/online-documentation
