We recently upgraded to 2008.1 from 2007.3. We are also now using VS2008 but compiling against the 2.0 framework. After the upgrade to 2008.1 the ultrawebmenu no longer works in Firefox. When I use firebug I get the following errors (4 times) for each menu item I select:
getFirstKbItem(undefined)ScriptResource.ax... (line 2431)
Subscribe to the RSS feed here
http://blogs.infragistics.com/blogs/vmcdonald/archive/2008/03/31/hot-fixes-delayed-march-april-2008.aspx
to be kept up-to-date on hot fix releases.
Any new news on when this hotfix will be available?
Yes, I can confirm that the fix is checked in and propagated in the earlier release branches that we have, including 7.2
It seems to me that this is happening in the 7.2 version as well? Is there going to be a hotfix for this in 7.2 as well?
Can you tell me issue number or the build number that will contain this fix. I called Developer Support and they could not seem to find the correct build that will address this issue.
