85
Problem with Client Side Sorting on Ultrawebgrid in Modal Popup Extender Control
We have an Ultrawebgrid inside ModalPopup Extender control in our application. In that ultrawebgrid we have one templeted column, in that we have checkboxes.  We are using client side sorting for that grid to sort data. If we sort any column, and then check some checkboxes and click Apply button to add the checked check boxes rows data into Database. But very first time after clicking on column header for sorting application is not recognizing the status of the checkboxes correctly, second time onwards it is working fine.
We are having the same in aspx page not in Modalpopexter, there it is working fine.
  • 7566
    Hello bhargavip,
    Thank you for posting in our community.  Which is the service release that you are using. In this case I can recommend you to upgrade to the latest service release and to test it again. In case that you experience the same issue. Attaching a sample for future investigation will be highly appreciated.
    For any further questions or concerns that you might have, do not hesitate to contact me.
    Sincerely,
    Georgi Sashev
    Developer Support Engineer
    Infragistics, Inc.
    http://es.infragistics.com/support
