1253
INotifyPropertyChanged does not get updated
I have a child window where I put a simple XamWebGrid containing 3 TextColumns.  I have an ObservableCollection named Person:
private string _firstname;
private string _lastname;
private string _phone;
public string FirstName
get { return _firstname; }
set
if (value != _firstname)
_firstname =
value;
onPropertyChanged(
this, "UserFirstName");
public string LastName
get { return _lastname; }
set
if (value != _lastname)
_lastname =
value;
onPropertyChanged(
this, "UserLastName");
public string Phone
get { return _phone; }
set
if (value != _phone)
_phone =
value;
onPropertyChanged(
this, "Phone");
public event PropertyChangedEventHandler PropertyChanged;
public void onPropertyChanged(object sender, string propertyName)
if (PropertyChanged != null)
PropertyChanged(
this, new PropertyChangedEventArgs(propertyName));
The following code is how I populate the data:
person.Add(
new Person()
FirstName =
"Tom",
LastName =
"Jones",
Phone =
"1234"});
person.Add(
new Person()
FirstName =
"Karen",
LastName =
"AAA",
Phone =
"87645"});
grdPerson.ItemsSource = person;
Below is my Xaml code:
<igGrid:XamWebGrid x:Name="grdPerson" AutoGenerateColumns="False" Grid.Column="0" Grid.Row="0" Visibility
="Visible" >
<igGrid:XamWebGrid.Columns
<igGrid:TextColumn Width="200" Key="FirstName" IsReadOnly="True" Visibility
="Visible" >
<igGrid:TextColumn.HeaderTemplate
<DataTemplate
<TextBlock Text="First Name" TextWrapping="Wrap"
</DataTemplate
</igGrid:TextColumn.HeaderTemplate
</igGrid:TextColumn
<igGrid:TextColumn Width="225" Key="LastName" HeaderText="Last Name" IsReadOnly
="False">
<DataTemplate
<TextBlock Text="Last Name" TextWrapping
="Wrap" />
</DataTemplate
</igGrid:TextColumn
<igGrid:TextColumn Width="225" Key="Phone" HeaderText="Phone" IsReadOnly
="False">
<DataTemplate
<TextBlock Text="Phone" TextWrapping
="Wrap" />
</DataTemplate
</igGrid:TextColumn
</igGrid:XamWebGrid.Columns
<igGrid:XamWebGrid.EditingSettings
<igGrid:EditingSettings AllowEditing="Row" IsEnterKeyEditingEnabled="True"
IsMouseActionEditingEnabled="SingleClick" IsOnCellActiveEditingEnabled="True"
</igGrid:XamWebGrid.EditingSettings
<igGrid:XamWebGrid.SelectionSettings
<igGrid:SelectionSettings CellClickAction="SelectRow" RowSelection="Single"></igGrid:SelectionSettings
</igGrid:XamWebGrid.SelectionSettings
</igGrid:XamWebGrid
To view the upated phone data changed, I have this code:
var qry = from rec1 in person
select rec1;
foreach (var item in qry)
MessageBox.Show("first phone " + item.Phone);
When I tried to change the phone numbers on both records, only the first record gets changed but not on the second one.  I noticed this only happen on the child window.  Can anyone help on this?  Thanks!
