230
Excel Copy Paste Sample
hello:
below is my sample for Excel Copy and paste. For some reason, I am unable to generate the Rows for the Sheets Dynamically, please could someone tell why?
 Thank you,
<%@ Control Language="C#" AutoEventWireup="true" CodeBehind="massGTINEditPortlet.ascx.cs" Inherits="dcdr.includes.controls.massGTINEditPortlet" %>
<%@ Register Src="~/includes/controls/clipboard.ascx" TagName="Clipboard" TagPrefix="uc1" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebGrid.ExcelExport.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.UltraWebGrid.ExcelExport" TagPrefix="igtblexp" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebNavigator.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.UltraWebNavigator" TagPrefix="ignav" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebGrid.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %>
<%@ Register Assembly="Infragistics35.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebTab.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebTab" TagPrefix="igtab" %>
<%@ Register tagPrefix="igmisc" namespace="Infragistics.WebUI.Misc" assembly="Infragistics35.WebUI.Misc.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" %>
function ShowContextMenu(evt){
//Firefox passes event arg as parameter (evt). If that is null, we'll use window.event (Internet Explorer proprietary)
var e=evt?evt:window.event;
//Call show menu with menuID
//specify clientX and clientY to get more accurate positioning for this particular layout
igmenu_showMenu("<%=this.CopyPasteMenu.ClientID %>",null,(e.clientX+document.documentElement.scrollLeft)+"px",(e.clientY+document.documentElement.scrollTop)+"px");
//Firefox (W3C) - cancel event
if(typeof(e.preventDefault)=="function")e.preventDefault();
//InternetExplorer (Proprietary) - cancel event
e.returnValue=false;
return false;
function GridClick(grid,src,button){
if(button!=2){
//Because the WebGrid consumes all mouse events, we need to add
//a listener to determine when a mouse click has occured so we can
//close the popup menu appropriately
igmenu_getMenuById("<%= this.CopyPasteMenu.ClientID %>").dismiss();
function ContextMenuItemClick(menuid,itemid)
//Grab a reference to the ContextMenuItem that was clicked on
var item=igmenu_getItemById(itemid);
var curGrid=null;
//We need to know which tab we're on, so we can figure out which
//grid we want to perform the copy/paste operation on.
//Notice we use the asp style tag to emit the ClientID of the tab.
//This makes our code more maintainable in the event that the tab
//id changes, the reference will be updated automatically.
var selTab=igtab_getTabById("<%= this.sheets.ClientID %>").getSelectedIndex();
curGrid=selTab==0?"<%=this.CopyPasteGrid1.ClientID %>":"<%=this.CopyPasteGrid2.ClientID %>";
curGrid=igtbl_getGridById(curGrid);
if(item!=null){
//We'll use the text from the menuitem to decide which operation to perform
switch(item.getText()){
case "Cut":
curGrid.cut();
break;
case "Copy":
curGrid.copy();
break;
case "Paste":
curGrid.paste();
break;
case "Export To Excel":
document.getElementById("ExportToExcelButton").click();
break;
</script>
<uc1:Clipboard ID="Clipboard1" runat="server" />
<table class="shade-white" cellspacing="0" cellpadding="0" width="100%" border="0">
<!-- B /// Title -->
<!-- There should be no reason to modify this section -->
<tr class="shade-purple-dark" valign="top">
<td><img height="11" alt=""
src="<%# RootURL %>/images/corners/top_l_666699.gif" width="11" border="0"
/></td>
<td class="skins-title-purple" valign="middle"><img
height="20" alt="" src="<%# RootURL %>/images/common/clear.gif" width="1"
align="absMiddle" border="0" />
<%# Title %>
</td>
<td align="right"><img height="11" alt=""
src="<%# RootURL %>/images/corners/top_r_666699.gif" width="11" border="0"
/></td>
</tr>
<!-- E /// Title -->
<!-- B /// VertBuffer -->
<!-- Vertical buffer to allow for sufficient spacing from the title and the content - should not be modified -->
<tr>
<td class="PortletBorderLeftRight" colspan="3"><img
height="1" alt="" src="<%# RootURL %>/images/common/clear.gif" width="1"
border="0" /></td>
</tr>
<!-- E /// VertBuffer -->
<!-- B /// ContentContainer -->
<tr valign="top">
<td class="PortletBorderLeft" width="3"><img height="1"
alt="" src="<%# RootURL %>/images/common/clear.gif" width="3" border="0"
/></td>
<td><br />
<!-- B /// Content -->
<!-- B /// MessageArea -->
<ul>
<asp:repeater id="rptMessages" runat="server" enableviewstate="False">
<itemtemplate>
<li class="error">
<%# DataBinder.Eval(Container.DataItem, "Text") %>
</li>
</itemtemplate>
</asp:repeater></ul>
<!-- E /// MessageArea -->
<!-- B /// DataList -->
<!-- /// ReVisit ClientSideEvents //<div class="view" oncontextmenu="BLOCKED SCRIPTShowContextMenu(event)">-->
<igtab:UltraWebTab Width="840px" runat="server" ID="sheets" CssClass="igwtMainBlack2k7" ImageDirectory="<%# RootURL %>/includes/css/office2007black/WebTabs/" TabOrientation="BottomLeft" ThreeDEffect="False">
<Tabs>
<igtab:Tab Text="Sheet1">
<Style Height="16px" Font-Size="x-small" CssClass="text" />
<ContentTemplate>
<igtbl:UltraWebGrid runat="server" ID="CopyPasteGrid1" Width="100%" Style="float:left;">
<Bands>
<igtbl:UltraGridBand>
<AddNewRow View="NotSet" Visible="NotSet">
</AddNewRow>
</igtbl:UltraGridBand>
</Bands>
<DisplayLayout SelectTypeCellDefault="extended" RowSelectorsDefault="yes" AllowRowNumberingDefault="Continuous" AllowSortingDefault="No" BorderCollapseDefault="Separate" CellClickActionDefault="CellSelect" Name="CopyPasteGrid1" RowHeightDefault="20px"
SelectTypeRowDefault="Extended" Version="4.00" ViewType="Flat" AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowDeleteDefault="Yes" AllowUpdateDefault="Yes" HeaderClickActionDefault="Select" SelectTypeColDefault="Single" TableLayout="Fixed" >
<ClientSideEvents MouseUpHandler="GridClick" ClipboardError="Grid_OnClipboardError" />
<GroupByBox>
<BandLabelStyle BackColor="#6372D4" ForeColor="White">
</BandLabelStyle>
<Style CssClass="igwgGrpBoxBlack2k7"></Style>
</GroupByBox>
<GroupByRowStyleDefault BackColor="#F4FBFE">
</GroupByRowStyleDefault>
<ActivationObject BorderColor="204, 237, 252" BorderWidth="1px" BorderStyle="Solid">
<BorderDetails WidthLeft="0px" WidthRight="0px" />
</ActivationObject>
<FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
<BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
</FooterStyleDefault>
<RowStyleDefault BackColor="Window" Height="19px">
<Padding Left="6px" />
<BorderDetails ColorLeft="230, 230, 230" StyleLeft="Solid" WidthLeft="1px" WidthTop="1px" StyleTop="solid" ColorTop="#f1f1f1" />
</RowStyleDefault>
<FilterOptionsDefault>
<FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
</FilterHighlightRowStyle>
<FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Width="200px">
<Padding Left="2px" />
</FilterDropDownStyle>
</FilterOptionsDefault>
<RowSelectorStyleDefault BackColor="White" BackgroundImage="none">
</RowSelectorStyleDefault>
<SelectedRowStyleDefault BackColor="#E0F1F9" BackgroundImage="<%# RootURL %>/App_Themes/Aero/row_selected_bg.jpg" BorderStyle="None" BorderWidth="0px" CustomRules="background-repeat: repeat-x;">
<Padding Left="7px" />
</SelectedRowStyleDefault>
<HeaderStyleDefault BackgroundImage="<%# RootURL %>/App_Themes/Aero/grid_header_selected_bg.jpg" BorderStyle="None" Cursor="Hand" Font-Bold="True" Font-Names="Trebuchet MS,Verdana,Arial,sans-serif" Font-Size="X-Small" ForeColor="#555555" Height="23px" HorizontalAlign="Center">
<Padding Left="5px" />
</HeaderStyleDefault>
<Images>
<CollapseImage Url="<%# RootURL %>/App_Themes/Aero/ig_treeArrowMinus.png" />
<FixedHeaderOnImage Url="<%# RootURL %>/App_Themes/Aero/ig_tblFixedOn.gif" />
<ExpandImage Url="<%# RootURL %>/App_Themes/Aero/ig_treeArrowPlus.png" />
<CurrentRowImage Url="<%# RootURL %>/App_Themes/Aero/ig_CurrentRow.gif" />
<FixedHeaderOffImage Url="<%# RootURL %>/App_Themes/Aero/ig_tblFixedOff.gif" />
</Images>
<SelectedHeaderStyleDefault BackgroundImage="<%# RootURL %>/App_Themes/Aero/grid_header_selected_bg.jpg">
</SelectedHeaderStyleDefault>
<EditCellStyleDefault CssClass="EditStyle" Height="19px" BackColor="White" BorderStyle="None" Font-Names="Trebuchet MS,Verdana,Arial,sans-serif" Font-Size="9pt">
</EditCellStyleDefault>
<FrameStyle BackColor="White" Width="100%" BorderColor="#E6E6E6" BorderStyle="Solid" BorderWidth="1px" Font-Names="Trebuchet MS,Verdana,Arial,sans-serif" Font-Size="X-Small">
</FrameStyle>
<Pager>
<Style CssClass="igwgPgrBlack2k7"></Style>
</Pager>
<AddNewBox Hidden="False">
<Style CssClass="igwgAddNewBoxBlack2k7"></Style>
</AddNewBox>
</DisplayLayout>
</igtbl:UltraWebGrid>
</ContentTemplate>
</igtab:Tab>
<igtab:Tab Text="Sheet2">
<Style height="16px" Font-Size="x-small" CssClass="text" />
<ContentTemplate>
<igtbl:UltraWebGrid runat="server" ID="CopyPasteGrid2" Width="100%">
<Bands>
</AddNewRow>
</Bands>
<DisplayLayout SelectTypeCellDefault="extended" RowSelectorsDefault="yes" AllowRowNumberingDefault="Continuous" AllowSortingDefault="No" BorderCollapseDefault="Separate" CellClickActionDefault="CellSelect" Name="CopyPasteGrid2" RowHeightDefault="20px"
SelectTypeRowDefault="Extended" Version="4.00" ViewType="Flat" AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer" AllowDeleteDefault="Yes" AllowUpdateDefault="Yes" HeaderClickActionDefault="Select" SelectTypeColDefault="Single" TableLayout="Fixed">
<GroupByBox>
</BandLabelStyle>
</GroupByBox>
</ActivationObject>
</RowStyleDefault>
<HeaderStyleDefault BackgroundImage="<%# RootURL %>/App_Themes/Aero/grid_header_bg.jpg" BorderStyle="None" Cursor="Hand" Font-Bold="True" Font-Names="Trebuchet MS,Verdana,Arial,sans-serif" Font-Size="X-Small" ForeColor="#555555" Height="23px" HorizontalAlign="Center">
<Images>
</Images>
</FrameStyle>
<Pager>
</Pager>
</AddNewBox>
</DisplayLayout>
</ContentTemplate>
</igtab:Tab>
</Tabs>
<DefaultTabStyle CssClass="igwtTabNormalBlack2k7" Height="22px">
</DefaultTabStyle>
<HoverTabStyle CssClass="igwtTabHoverBlack2k7">
</HoverTabStyle>
<RoundedImage FillStyle="LeftMergedWithCenter" HoverImage="igwt_tab_hover.jpg" LeftSideWidth="14"
NormalImage="none" RightSideWidth="14" SelectedImage="igwt_tab_selected.jpg" />
<SelectedTabStyle CssClass="igwtTabSelectedBlack2k7">
</SelectedTabStyle>
</igtab:UltraWebTab>
<asp:Button runat="Server" ID="ExportToExcelButton" Text="Export to Excel" OnClick="ExportToExcel" CssClass="exportButton" />
</div>
<igtblexp:UltraWebGridExcelExporter ID="UltraWebGridExcelExporter1" runat="server" DownloadName="Workbook1.xls" ExportMode="Download" >
</igtblexp:UltraWebGridExcelExporter>
<ignav:UltraWebMenu TopAligment="left" TopItemSpacing="Compact" ID="CopyPasteMenu" runat="server" WebMenuStyle="XPClient" WebMenuTarget="PopupMenu" CssClass="ContextMenu" EnableViewState="False">
<MenuClientSideEvents ItemClick="ContextMenuItemClick" />
<SeparatorStyle CustomRules="background-repeat:repeat-x;" BackgroundImage="<%# RootURL %>/css/office2007black/webmenu/igMenuSeparator.jpg" />
<Items>
<ignav:Item Text="Cut">
<Images><DefaultImage Url="<%# RootURL %>/css/office2007black/webhtmleditor/cut.gif" AlternateText="Cut" />
</Images>
</ignav:Item>
<ignav:Item Text="Copy">
<Images><DefaultImage Url="<%# RootURL %>/css/office2007black/webhtmleditor/copy.gif" AlternateText="copy" />
</Images>
</ignav:Item>
<ignav:Item Text="Paste">
<Images>
<DefaultImage Url="<%# RootURL %>/css/office2007black/webhtmleditor/paste.gif" AlternateText="paste" />
</Images>
</ignav:Item>
<ignav:Item Separator="true" >
</ignav:Item>
<ignav:Item Text="Export To Excel">
<Images>
<DefaultImage Url="./excelicon.gif" AlternateText="Export To Excel" />
</Images>
</ignav:Item>
</Items>
<ItemStyle CssClass="ContextMenuItem" />
<HoverItemStyle CssClass="ContextMenuItemHover" />
<ExpandEffects ShadowColor="LightGray" />
</ignav:UltraWebMenu>
<!-- E /// DataList -->
<!-- B /// Buttons -->
<!-- E /// Buttons -->
<!-- E /// Content --></td>
<td class="PortletBorderRight" width="3"><img alt="" border="0" width="1" height="1" src="<%# RootURL %>/images/common/clear.gif" /></td>
</tr>
<!-- E /// ContentContainer -->
<!-- B /// BottomColSizer -->
<!-- Cap the container and provide column sizing - should not be modified -->
<tr valign="bottom">
<td width="11"><img height="11" alt=""
src="<%# RootURL %>/images/corners/bottom_l_line_666699.gif" width="11"
border="0" /></td>
<td class="PortletBorderBottom"><img height="1" alt=""
src="<%# RootURL %>/images/common/clear.gif" width="1" border="0"
/></td>
<td align="right" width="11"><img alt="" border="0" width="11" height="11" src="<%# RootURL %>/images/corners/bottom_r_line_666699.gif" /></td>
</tr>
<!-- E /// BottomColSizer --></table>
<script type="text/C#" runat="server">
protected void ExportToExcel(object sender, EventArgs e)
Infragistics.Excel.Workbook workbook = new Infragistics.Excel.Workbook();
workbook.Worksheets.Add("Sheet1");
workbook.Worksheets.Add("Sheet2");
this.CopyPasteGrid1.DisplayLayout.ColHeadersVisibleDefault = ShowMarginInfo.No;
this.UltraWebGridExcelExporter1.Export(this.CopyPasteGrid1, workbook);
for (int i = 0; i < this.CopyPasteGrid1.Columns.Count; i++)
workbook.Worksheets[0].Columns[i].Width = 2000;
this.CopyPasteGrid2.DisplayLayout.ColHeadersVisibleDefault = ShowMarginInfo.No;
workbook.ActiveWorksheet = workbook.Worksheets[1];
this.UltraWebGridExcelExporter1.Export(this.CopyPasteGrid2, workbook);
for (int i = 0; i < this.CopyPasteGrid2.Columns.Count; i++)
workbook.Worksheets[1].Columns[i].Width = 2000;
workbook.ActiveWorksheet = workbook.Worksheets[0];
protected void Page_Load(object sender, EventArgs e)
//this.WebPanel1.Visible = WebSamplesCS.Config.ShowDescription;
if (!this.IsPostBack)
int max_rows = 28;
int max_cols = 16;
String alphabet = "abcdefghijklmnopqrstuvwxyz";
for (int j = 0; j < max_cols; j++)
this.CopyPasteGrid1.Columns.Add("Col" + j, alphabet[j % 26].ToString().ToUpper());
this.CopyPasteGrid2.Columns.Add("Col" + j, alphabet[j % 26].ToString().ToUpper());
for (int i = 0; i < max_rows; i++)
this.CopyPasteGrid1.Rows.Add();
this.CopyPasteGrid2.Rows.Add();
this.CopyPasteGrid1.Rows[0].Cells[0].Text = "Sample";
this.CopyPasteGrid1.Rows[0].Cells[1].Text = "Data";
</script>
  • 13438
    Suggested Answer
    Hello Sushma
    I know it has been a while since you asked this question  but in case you still need assistance I will be glad to provide an answer. I could not create a sample based on your code sniped due to many undefined css classes referenced in not attached files. Please always provide a small runnable sample and attach it as archive in order to provide you better support. However please refer to the following forum thread where a similar answer has been asked - http://community.infragistics.com/forums/p/37686/282422.aspx#. You can also check the following blog regarding copy-paste functionality - http://community.infragistics.com/blogs/alex_kartavov/archive/2010/02/09/copy-paste-from-excel-to-webdatagrid.aspx
