760
Conditional formatting - cell border paint issues
I have the following styles defined in my xaml file..
   <UserControl.Resources>
            <Style x:Key="redStyleNumber" TargetType="ig:PivotCellControl">
                <Setter Property="Foreground" Value="Red" />
                <Setter Property="HorizontalAlignment" Value="Right" />
        </Style>
            <Style x:Key="normalStyleNumber" TargetType="ig:PivotCellControl">
                <Setter Property="Foreground" Value="Black" />
        </Style>
and using those styles as shown below in codebehind..
 private void pivotGrid_CellControlAttached(object sender, Infragistics.Controls.Grids.PivotCellControlAttachedEventArgs e)
            int column = this.pivotGrid.DataColumns.IndexOf(e.Cell.DataColumn);
            int row = this.pivotGrid.DataRows.IndexOf(e.Cell.DataRow);
            if (this.pivotGrid.DataSource != null && pivotGrid.DataSource.Result != null)
                ICell cellData = this.pivotGrid.DataSource.Result.Cells[row, column];
                if (cellData != null && (cellData.Value is double?))
                    double value = (double)cellData.Value;
                    if (value < 0)
                        e.Cell.Style = this.Resources["redStyleNumber"] as Style;
                    else
                        e.Cell.Style = this.Resources["normalStyleNumber"] as Style;
                    e.IsDirty = true;
the problem is... the cell borders are not rendered correctly with this code.. Didn't create a separate sample for this... Hopefully you'll be able to reproduce with the above code..
