60
Row data lost on postback
Greetings. I'm totally perplexed at this point.
I have a webgrid that I load rows manually via creating  rows and adding them at runtime, I have no bound columns, I just load some custom values i need to manipulate via code then append to the rows collection such as
Dim uwgCell As New UltraGridCell
uwgCell.Text = CLng(SqlDR("SectionId"))uwgCell.Value = CLng(SqlDR("SectionId"))
uwgRow.Cells.Add(uwgCell)
then
UltraWebGridSectionsQuizzes.Rows.Add(uwgRow)
I do this for about 50 rows.
This is done on the form load event inside the if not Ispostback statement.
The problem is when a postback occurs the row data disappears. It's not persistant. I also group on a column which still shows correctly with the group header but the child rows show but with no data. Need help badly before I pull my hair out.
 Thank you much.
